200whp 2.2
#102
i wasnt expecting 200 with these mods...but i was saying it is possible based on what i will be showing when this set is done
#108
Just a little bit. The mid and high torque makes up for the lost low end. As long as you have it tuned perfectly, you shouldnt have much lag in the low end. You can expect some loss in low end torque because of the characteristics of stage 2 cams. If your experiencing sluggish takeoffs, have vince advance your timing a little bit more. Im running 23-24 degrees i believe. Also are you running 91 or 93 octane?
