30 more whp?
#51
Originally Posted by Cobalter LS
Actually the MAF is only part of the equation. The exhaust O2 sensor gives a signal that the PCM uses to adjust fuel amounts. If more air enters the engine the O2 sensor signal adjusts for the increase in O2 content and the PCM increases fuel flow to compensate. That's why computer cars no longer need chokes, the PCM adjusts fuel flow based on preset parameters until the O2 sensor can provide the neccessary data.
#52
Originally Posted by NJHK
Actually I did know that but I really didn't want to get in too detail. But thanks.
#54
#55
#57
#58
well id need an extra ecu...i only have one car...so..yeah. and what would i tell him....crack this encryption? is it just encrypted or what?
i really am concidering it tho....he really is a hacker
he built me a program to get some CD keys to any software i have and its a really short bit of script too
#59
with a computer you can find back doors and use little tricks, but with an ecu it is a matter of actually tricking it into doing what you want. Flash tuners and stuff basically tell the computer something false thru the sensors and alters what it reads so it will control the fuel delivery and timing in the way you want. figuring out how to trick the ecu and what kinda coding it uses is alot more complicated on some than others. Since i beleive your obd II sensor has some kind of protection (heard that on another forum, i think the ecotec forums) it will have to be done differently. I do not know exactly how it works, but i know it is a complicated process of guessing and checking to get the ecu to be able to be tuned.
jcalvin1126
09-11-2015 10:24 AM
