600+ hp 2.2l?
Old 03-13-2009, 11:13 AM
  #51
Gestapo007's Avatar
wont a twin turbo just put out more boost then our little 4 bangers can handle?
Old 03-13-2009, 11:16 AM
  #52
roadrage06's Avatar
A V-style engine uses a turbo on both sets of exhaust pipes.
On a single outlet engine (like a 4-banger) they stack them. Sometimes they use a smaller one to spool the little one -- piggy backing them to decrease lag time and increase boost. I guess it could work. As for handling it.......that is why he's building the motor.
Old 03-13-2009, 11:17 AM
  #53
Sentry's Avatar
Originally Posted by roadrage06
Huh? Ferrari's and Lambo's use naturally aspirated engines.
Yeah, you're right. Who needs forced induction when you've got 12 cylinders.
Old 03-13-2009, 11:18 AM
  #54
KyleMinnis's Avatar
this is completely out of hand.
Old 03-13-2009, 11:20 AM
  #55
Brandon97Z's Avatar
Originally Posted by Sentry
Hahn has a 2.2L project car over 400hp? Anyone got a link?
If not, then I think you mean the F35 transmission, which is rated considerably higher and is for the SS.
check out their sunfire...you can prolly find more info on jbody.org...even though i've seen them post pics and info over here aswell.
Old 03-13-2009, 03:12 PM
  #56
Nato09's Avatar
But, it makes no sense to twin turbo a 4 cylinder, leave that to the V motors that can put out the proper amount of exhaust.
i heard from my brother there is a guy that twin turboed his cobalt (not sure the displacement). there is a smaller turbo that feeds the bigger turbo resulting in 50+ lbs of boost. he also put over 50grand into the car though.. id like to see the dyno numbers though. they have to be rediculous.
the 2-step is essentially the same as launch control, where it holds your RPMS at whatever you set it at letting your turbo spool b4 you drop the clutch. That would be a great idea. just be careful with the NOS and get it done right.
couldnt i also use the WOT box to help spool the turbo at launch?
Old 03-13-2009, 03:14 PM
  #57
fredds-turbaltSS's Avatar
i believe when you have two turbos one spolling the others its refered to a bi-turbo set up
Old 03-13-2009, 03:17 PM
  #58
roadrage06's Avatar
yes, the two terms are used interchangeabley (incorrectly) but are not synonymous.
Old 03-13-2009, 03:20 PM
  #59
Nato09's Avatar
soo..does that mean that ferrari with the bi-supercharged system uses one supercharger to crank the other? i thought they both ran off the crank?
Old 03-14-2009, 01:22 AM
  #60
HunterKiller89's Avatar
same ****. you can route the belt either way you want, but in the end, the crank is running both of them.
im pretty sure the smaller turbo spooling a larger turbo is called a sequential turbo setup. A bi-turbo setup is just the european equivalent to a twin turbo setup. Im pretty sure AMG's engines use twin turbos, but theyre all called bi-turbo cars.
the guy with the bi-turbo car btw was Victory_red_ss. He did spend like $50k on his car. Sequential turbos, RWD conversion, etc. It was a big build.
Old 03-22-2009, 12:55 PM
  #61
zay52790's Avatar
It can be done, but id go straight turbo, and a big ass one, and it would cost alot more than 7500 to pull it off, just becuase of all the suppoting mods you would need
Old 03-22-2009, 01:00 PM
  #62
Sentry's Avatar
I agree, on a 4 cylinder you get a lot more efficient setup by running just one big turbo than twinturbo/twincharged. Leave twin turbos to v6 and v8, and twincharging is just a lot of work.
Old 03-22-2009, 01:52 PM
  #63
Gestapo007's Avatar
^agreed.
Turbo, WOT box, nice exhaust setup, and big shift light staring you in the eyes. SEX
Old 03-23-2009, 01:22 AM
  #64
Nato09's Avatar
how would i fit a gt35 back there? there is barely any room
Old 03-23-2009, 09:30 AM
  #65
MadBrad's Avatar
why? bc i would like to walk covettes with my little underestimated 4-cyl.
1st gear spin, spin, hop, 2nd gear spin, hop, spin, and 3rd gear, spin, little traction, crap where the corvette go. Crap it was a Z06 . Anything over 500hp on FWD not effecient.
Old 03-23-2009, 10:25 AM
  #66
Sentry's Avatar
Not on street tires anyways. But yeah, you can fit a big turbo behind the firewall, vulcan makes a nice manifold for that, it's angled downward more.
Old 03-23-2009, 11:46 AM
  #67
DirtySanchzN64's Avatar
Thumbs up
Originally Posted by IonFeright
First youd have to swap out just about every oem drivetrain, engine, and suspension part on your car.
After youve concurred that youd have to convert to full standalone cuz no way the stock computers gonna handle anything near that. And since NO ONE has gone standalone yet, that will be a mammoth project.
So in short like everyone else has stated... just not worth it!
it would be a mammoth of a project yeah but if ur willing to put the money in and the time, then do it...i dont think it would be a great car to drive to work and back, but a 9 or 10 second 2.2 cobalt would be amazing!!
Old 03-23-2009, 01:07 PM
  #68
cobaltracrtc's Avatar
hey man look at the gm ecotec build book it will tell you what to do to achive your hp desire
Old 03-23-2009, 10:34 PM
  #69
Tinkles's Avatar
Hahn sunfire's dyno numbers
Im pretty sure their sunfire has been destroked.
Skunk on JBO is shooting for 500whp on his new set-up and Daflyingskwirl is going for big numbers and low E/Ts, but he is running a LSJ bottom end.
Old 03-23-2009, 11:11 PM
  #70
aterminatorz's Avatar
Your only hope would be to follow the GM Build Book. If you don't follow the recipe, it won't come out right and you with have countless unforeseen problems. You can't just install all these parts and go fast successfully, you have to work progressively over a period of years.
You do realize that you will not be able to drive your car on the street anymore. Also you will need a roll cage and possibly a parachute if you can get the thing to hook up.
So in addition to parts and labor for your car, you will need a towing vehicle, a trailer, and possibly another vehicle as a daily driver. That sounds like tens of thousands of dollars to me.
Honestly cars at that level are owned by race teams that have sponsors($$$) to pay for tools, parts, engineers, and mechanics.
Cobalts are FWD, which = fail for launching from a dig or putting power to the ground efficiently.
You can go much faster, for a lot less money, in a different car. Get something that is RWD or AWD, those layouts have superior launching abilities. Launching can be the most crucial thing to winning 1/4 races.
Good luck.
Old 03-23-2009, 11:55 PM
  #71
Nato09's Avatar
alrighty so im looking at investing in the following:
gt35r turbo kit
3" catback
WOT box
sticky sticky tires
solid motor + tranny mounts
stg 2 clutch
tune
pistons + rods
anything i missed?
Old 03-24-2009, 12:00 AM
  #72
Tinkles's Avatar
sleeves, cams, fully built P&P head, customs intake and exhaust manifolds
I highly doubt a stage 2 clutch will hold the power. A twin disc clutch would be a better choice.
Old 03-24-2009, 12:13 AM
  #73
drew1991sf's Avatar
drop a lsj or lnf motor in it along with tranny and mod that
  #74
06_ion2's Avatar
gt35r turbo kit
3" catback
WOT box
sticky sticky tires
stg 2 clutch
tune
pistons + rods
anything i missed?
this is what i have and i doubt it would support anymore than 450whp.. your talking about huge huge money for 450+whp im already going to be at close to 12k total
procharger kit
vulcan intake mani
ZZp header/downpipe
spec 3 clutch
8.9:1 wiseco pistons
eagle rods
ARP headstuds
2.4 tb
Fmic + 2.5in pipe
B&G coilovers
patriot stage 2 head
exhaust mani gasket
throwout bearing
79lb injectors + harness
Cosmetic head gasket
Walbro 255 LPH Fuel Pump
stage 2 axels - still need
Spanky's Monkey
03-07-2016 06:06 PM
ThoR294
10-04-2015 08:44 PM
09-26-2015 06:44 PM
jmelton327
09-24-2015 01:40 PM
CobaltSS 16
09-06-2015 02:04 PM
Quick Reply: 600+ hp 2.2l?
