60lb injector help
60lb injector help
alright heres my dilemma, i have 42 installed right now and im upgrading to 60s, well the harness i have that came wit the injectors doesnt fit, i think the harness is from a LSJ and the injectors are Siemens and EV1 style. would it be safe to just splice and wire into my harness i have already?
that wat i was plannin on doin but when i look at the wires the colors are different and i dont wanna get any mixed up. would it help if i took pics of the harnesses and injectors for ease of assistance?
well after lookin at the wires i see there is for example a red wire and a green wire wit a white stripe, im guessing i splice the 60# injectors using red to red and the 2 other colors connect to each other?
Last edited by BlackCobalt707; 01-30-2010 at 08:54 AM. Reason: Automerged Doublepost
Well when i got my harnes it had just the pins at the end and no black plastic connector..
So when i went to repin it i just looked and my stock injector connector and took out then replaced the pin with the one from the lsj connector.. if u look at the connector closely they have two letters on them.. one on each side A&D
Lemme know if u r getting me so far?
Well the guy i got em from had did the same thing so he just sent them that way.. was easy.. they had the pins still just no black plastic connector
took me about 10 mins to do and no cutting
hmm, if its that easy and fast i might just go that way about it, thanks
alright, i got my 42s off my car and i put my 60s in the fuel rail to keep fuel from comin out, can you walk me thru the process of wat to do?
Last edited by BlackCobalt707; 01-30-2010 at 11:12 AM. Reason: Automerged Doublepost
yeah its simple man.. just have both harnesses in front of u.. as u get one pin?wire out put the one from the other harness in.
Just make sure when u start to take off the lil purple clip thing holding the wires into the connector. then just get some needle nose pliers and just gently wiggle and push em out from the front.
And i thing u should only be pulling five wires from ur stock.. 1 for each injector and 1 ground which is the one on the bottom row of the connector. The other ones on the bottom belong to ur MAP sensor..
Am i making any sense?
alright i got ya, i just was tryin to figure out the correct way of takin out the pins, i dont got no needle no pliers tho. but yea you are makin sense
my stock harness has 8 wires. 5 for the injectors and 3 for the map
Last edited by BlackCobalt707; 01-30-2010 at 11:20 AM. Reason: Automerged Doublepost
Yep same here man..
And hmm well the way i did it is i GENTLY pulled and wiggled from the back.. They came out pretty easy but i was told not to do that cause u can pull the wire outta the pin. but mines didnt do that thankfully!
well i tried the repinning way but i couldnt get it so i said **** it and spliced them and heat wrapped them up
i appreciate the help guys, thanks
will i have any impedence (spelling?) issues? or whatever can happen to my computer. my friend told me to ask about it
Last edited by BlackCobalt707; 01-30-2010 at 05:38 PM. Reason: Automerged Doublepost
