60lb injector help
Old 07-23-2010, 01:00 PM
BlackCobalt707's Avatar
Originally Posted by Sw4y1313
The size of the injectors isnt going to effect how rich or lean you run(Only if you can't supply the amount of fuel you need for the airflow coming in). Its the tune. If you want larger injectors incase you plan on going with more power later, you just tune for that.
i couldve sworn i read somethin about going too big and youll run rich if youre not supplyin enough air....or somethin about duty cycle. i cant remember. but hell i guess you learn somethin new every day
Originally Posted by Spanky's Monkey
that sounds about right for a turbo build. i could be wrong but you're wot sounds good.
i was at 11.5-11.7
Last edited by BlackCobalt707; 07-23-2010 at 01:00 PM. Reason: Automerged Doublepost
Old 07-23-2010, 05:27 PM
Spanky's Monkey's Avatar
running rich with a turbo @ wot is gonna help keep the engine cooler. the leaner you get the more dangerous territory you're looking at. you'll make more efficient power but you'll be adding stress due to the higher heat temps.
Old 07-23-2010, 05:29 PM
which is where my meth comes in lol
Old 08-02-2010, 08:56 PM
My boost is back!!!!
05-28-2022 03:47 AM
DarrenGC
12-24-2021 01:55 PM
Sl0wbaltSS
11-21-2018 11:11 PM
patooyee
10-15-2015 05:11 PM
yellow dragon
09-28-2015 09:49 PM
Quick Reply: 60lb injector help
