7k rev limiter
Old 05-26-2009, 01:19 PM
Chuck's Avatar
I would replace the oil pan, you can get a used one or buy a new one..its not hard to do.. because if its cracked then its weak.. Welding may fix it, but that does change the temperament of the metal..
Old 05-30-2009, 08:58 PM
jbenso4's Avatar
get a new oil pan. you will be paying for it in oil in the long run.
Old 05-30-2009, 11:13 PM
umrdyldo's Avatar
Don't quote me, but drain the oil, get new pan and gasket. Should be just unbolted and changing gasket and pan.
Might want to look into torque specs and order of tightening. Pretty simple really
Old 05-30-2009, 11:37 PM
jbenso4's Avatar
extremely simple
Old 05-31-2009, 11:32 PM
lwpmoon's Avatar
^^ He's right But their is no gasket. They use Engine Sealant GM part #12378521 around the perimeter and the oil feed of the pan. The oil pan is hard as hell to get off, you might want a pry-bar. As for the torque specs, its 18 ft/lb. Fairly easy.
Old 05-31-2009, 11:34 PM
06_ion2's Avatar
you will be fine im running 7k boosted on my stock head.
Old 05-31-2009, 11:39 PM
EXsoccer1921's Avatar
you'll be fine, i was in 4th gear between 7k-7300 for about 10seconds last night. no problems here
Old 06-01-2009, 12:07 AM
blackbolt89's Avatar
you has a ss/sc
different valvetrain if i'm not mistaken?
Old 06-01-2009, 12:15 AM
06_ion2's Avatar
Originally Posted by blackbolt89
you has a ss/sc
no just different valves. but still you will be safe to rev to 7k. ive done it alot
Old 06-01-2009, 02:18 AM
HunterKiller89's Avatar
you has a ss/sc
same valvetrain. Even same intake valve and cam profile
Old 06-01-2009, 02:26 AM
  #36
06_ion2's Avatar
i thought the valves were made out of a different material.
Old 06-01-2009, 10:53 AM
  #37
oh i didn't know that.
Old 06-01-2009, 08:11 PM
  #38
i think the intake valve is the same between the motors. Its only the LSJ's exhaust valve that is sodium filled. I'm not positive, but pretty sure
Old 06-02-2009, 01:27 PM
  #39
ryansalazan's Avatar
so basically to sum it up, its ok for 7,000 cause i want to do that for my car but i wont rev that high all the time
Old 06-02-2009, 01:54 PM
  #40
yes, 7,000 is fine to hit daily. 7,200-7,300 is where it gets iffy. 7,500 should be a "its not the end of the world, but dont do it regularly" zone
Old 06-02-2009, 04:15 PM
  #41
Chuck's Avatar
The heads will go to 7500...but there is no use.. the stock internals can not handle that long.. and the head its self does not flow enough to be making power at that high of RPM's..
Old 06-02-2009, 06:00 PM
  #42
tru2nrtt777's Avatar
lol problem with that. oil pan has a tiny crack in it. don't know how. must have been the previous owner. now that i know i carry a quart in my trunk and check the oil every other day.
anyone know an easy way to fix an oil pan?
Weld it, or buy my spare oil pan, it has no cracks and has 40k on it.
Correct until 07:
 Intake cam is longer than exhaust cam.
 Uses “waste spark” control system, so there is no cam position sensor.
 Intake cam is the same casting as the LSJ intake and exhaust cam, but lacks the pressed-in hex.
 Compatible with GM Performance Parts adjustable cam gears.
 Can be replaced by GM Performance Parts matched cam set (requires Bates Enginering valve springs and retainers to prevent coil bind) or other aftermarket cams from Comp Cams.
07 cams are different.
 New intake cam has a wheel-style cam position sensor.
 Intake cam is not interchangeable with any other ECOtec cams, nor with the GMPP intake cam.
 Exhaust cam casting is the same as previous model years, with a slightly different cam profile
 Exhaust cam is interchangeable with the GMPP exhaust cam (requires upgraded valve springs and retainers).
Old 06-03-2009, 10:34 AM
  #43
Correct until 07:
pm me with pricing.
Iceberg
09-29-2015 12:33 PM
Iceberg
09-28-2015 01:31 PM
z28addiction
09-28-2015 12:03 AM
grampss
09-27-2015 08:51 PM
DocSvensk
09-27-2015 02:24 PM
Quick Reply: 7k rev limiter
