I would like to make about 245 hp about what do I need to make it. this is what im thinking
Garrett alpha (when tuning available) $3699
VIBRANT 3" Catback $550
B@m shift pulse $40
What else do i need
Trans cooler ???
oil cooler???
This is just for an estament of what it will cost thanks
B@m shift pulse $40
What else do i need
Trans cooler ???
oil cooler???
Injen Cold Air Intake $250
B@m shift pulse $40
What else do i need
B@m shift pulse $40
What else do i need
You're on the right track, however your most likely going to run into trans reliability issues.
Better Drive Shafts
Motor Mounts
Trans mounts
Trans Cooler
Oil Cooler
You dont need an intake because the turbo kit will come with one. Like said above, a tranny cooler is pretty much what your missing. I would go with a custom 3" exhaust from a local shop because your going to save a lot of money doing it that way and should be happy with the results. If you want to go any higher then say 220whp, you will need to get some new pistons. The stock pistons are just horrible, and i wouldnt trust the rods either. So was it 240whp or 240bhp because the Garrett Alpha kit will get you pretty close to 240bhp.
