AEM fuel/ignition controller
Old 02-14-2008, 08:58 AM
  #101
Witt's Avatar
Originally Posted by HunterKiller89
i gotta agree with ionninja in that i specifically remember seeing the field where you input your MAF clamp voltage
/facepalm
Originally Posted by Witt
Digital ones report back a frequency analog report a voltage 0-5v.
Originally Posted by zinner
There are devices out there that can modify and clamp the GM style MAF.
MAF-T and SMT6/7 are a couple.
Old 02-14-2008, 01:00 PM
  #102
IonNinja's Avatar
Originally Posted by tru2nrtt777
Already got done with one of my electrical classes hence me actually being remotely knowledgable about this stuff.
no wonder, I have no books so I learn from trial and error
yes there is a field for clamping MAF voltage, I know that 100% but I don't remember anything in there in regards to frequencies.
A work around is to build a larger diameter custom intake pipe. More airflow will go by at a lower frequency.
I don't know if Cobalts are the same but the Ion ECU seems to throw a CEL with larger diameter piping. So all the ones available are narrowed down around the MAF.
***************************/garage.php?...d&image_id=127
Whats a workaround for that?
Old 02-14-2008, 01:04 PM
  #103
Witt's Avatar
The reason is because more airflow is going by at a lower frequency. You tune the fuel trim down to 0 after increasing pipe diameter. It gives a check engine light becuase the trims exceed a certain value which is fixed with the FIC.
Old 02-14-2008, 01:16 PM
  #104
IonNinja's Avatar
ahhhhh okay
Old 02-14-2008, 01:17 PM
  #105
Cobalt4Life's Avatar
im having a brain fart, ion did ya get the aem fic yet??
Old 02-14-2008, 01:44 PM
  #106
IonNinja's Avatar
no I haven't bought anything yet...the FIC if I decide on that piggyback, will probably be the last thing I buy. I'm still undecided on a piggyback so far...
I still need a set of cams and a wideband and then if its necessary I'll go with a piggyback to fine tune everything.
i'm a little disappointed though because I want the FT40 from perfect power but it seems like it doesn't have the ability to do anything other than adjust fuel trims. I really want that rev limit extender though...
Old 02-14-2008, 01:48 PM
  #107
did ya call them and ask?? ya could get the stage 2 cams.. i am suprised with cams and all u dont go high compression as i thought u were going for all NA
Old 02-14-2008, 02:01 PM
  #108
IonNinja's Avatar
I do want the stage 2 comp cams but no sense in getting them if I'm only taking the motor to 6500. might as well get some cams that improve on the low end if I'm gonna be limited to that...
yeah I wont be touching the bottom end on this car at all, I'm not going that extreme. I just want something capable of a 13 sec. pass (or atleast a 13sec. trap )
if i do tear a motor apart its gonna be on a project car where i can afford the downtime...but yes you are right, my plan with this car is n/a + nitrous
Old 02-14-2008, 02:35 PM
  #109
id give diamond a call they build high compression pistons for a good price.. that and some new rods and nitrous, youd be hitting good times and still would be saving money.. well then stage 1 cams?? with all that ud be set
Old 02-14-2008, 03:18 PM
  #110
IonNinja's Avatar
yeah the plan so far is...
comp stage 1 cams
AEM wideband
Dynotune Nitrous Gauge
2 Pod Gauge pillar
AEM FIC (or other piggyback)
coilovers
thats really all I have left on the parts list for this car...after that I'll probably start another project. I'm really interested in boosting a 92-93 Integra LS as those motors have been known to take 300whp on a stock bottom end (with good tuning of course). plus, if it breaks it doesn't really matter because I will still have the Ion to drive everyday.
Old 02-14-2008, 03:21 PM
  #111
they have the autometer cobalt series nitrous gauge
if id get any car for a beater and **** it would be a nova.. there is one to many around here i could get for 2k in decend shape.. add a turbo to that mwahah..
05-28-2022 03:47 AM
01-12-2016 12:01 AM
yellow dragon
09-28-2015 09:49 PM
09-27-2015 08:53 PM
Coballin13
09-25-2015 08:43 AM
Quick Reply: AEM fuel/ignition controller
