Aluminium shaving on oil filter
So, I did the 1st oil change on my base 2.2 (3400 mi) and noticed fairly good sized
alu shavings on the filter as I pulled it out. Being a mechanic I know this is not a good
thing. What I would to know is if chevy has any T.S.B's and/or if anyone else has
experinced this and what the resolution was. Thanks:
Document ID# 1722668
2006 Chevrolet Cobalt
Subject: Machining Debris on the Oil Filter Element - keywords aluminum change chips contamination engine metal shaving #PIP3404B - (11/04/2005)
Models: 2005 Chevrolet Cavalier
2005-2006 Chevrolet Cobalt
2006 Chevrolet HHR
2005-2006 Chevrolet Malibu
2005 Chevrolet Malibu Classic
2005 Pontiac Grand Am
2005-2006 Pontiac Pursuit (Canada Only)
2005 Pontiac Sunfire
2005-2006 Saturn Ion
2005 Saturn L Series
2005-2006 Saturn Vue
with 2.2L Engine (VIN D or F - RPO L61)
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
On rare occasions, machining debris may be found on the oil filter element during the vehicle's first oil change. This debris consists of small boring chips and milling burrs from the oil passage that is between the oil pump and oil filter.
Recommendation/Instructions:
If this condition is encountered, replace the engine oil and filter. No additional repairs should be attempted since this debris does not affect the reliability or durability of the engine.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
GM bulletins are intended for use by professional technicians, NOT a "do-it-yourselfer". They are written to inform these technicians of conditions that may occur on some vehicles, or to provide information that could assist in the proper service of a vehicle. Properly trained technicians have the equipment, tools, safety instructions, and know-how to do a job properly and safely. If a condition is described, DO NOT assume that the bulletin applies to your vehicle, or that your vehicle will have that condition. See your GM dealer for information on whether your vehicle may benefit from the information.
WE SUPPORT VOLUNTARY TECHNICIAN CERTIFICATION
© Copyright General Motors Corporation. All Rights Reserved.
I ran into the same thing on my Cobalt. First oil change at 1,000 miles had a few metal shavings in the oil filter. I'm now at about 12,000 miles and about five oil changes later with no problems. I've found no more metal in the filter and the car runs great.
2006 Chevrolet HHR
Condition/Concern:
i had alot of shavings on my first oil change too. ive changed the oil 3 times since then and no shavings. just leftover machining debris and debris from internals seating themselves.
importkiller
09-30-2015 07:18 PM
