another tuning option
well lets say for argument that we have a 2.2L Base model Cobalt/Pursuit. It has airbags and power locks but thats it. No ABS, Traction control, Stabilaty Control, or any kind of driver assist. The transmission is also a manual not an auto. By adding a SAFMS, the air bags and door locks and driver comforts such as A/C, Cruise, Driver Information Center and Security system are all disabled. Generaly speaking, these systems do no make the car street legal, they make it safer/more comfortable. The vehicle would still run and pass standerdized provincial saftey testing (i don't know about US rules on safeties but im sure thier close to being the same as ours). Which brings me to belive that SAFMS are street LEGAL, its just all these years people belived diffrently because they disabled such systems as airbags and TRAC-Control. just my 2cents
This is what you have to consider as well.
You're making some sense but the fact of the matter is that it really depends on alot of things...for example, what state you live in, how strict they are and things of that nature. If they open your hood and see a monstrous turbo charger that they KNOW is not supposed to be in your vehicle, chances are they would tell you that you failed regardless of your emissions. I know people in jersey where they gave them a hard time for having an intake...
this is also true. There are alot of things to consider before going this route.
I'm using SAFC for more accuracy - 12 points of adjustment vs 5 on the DFMU - in tuning across the band.
ECM tuning will provide even more accuracy as well as capability for adding/removing timing to handle even more boost.
SAFC works fine, just have to put in the RL injectors i've got and i'll be set until we get some ECM tuning
Using SAFC for more accuracy - 12 points of adjustment vs 5 on the DFMU - in tuning across the band.
even if you wanted to be a smartass, both are still cheaper than a) not tuning and blowing myself up or b) buying an ECM programmer (like HPTuners)
"not effective" implies it has no effect. it definitely does. efficient, maybe not, but it gets the job at hand accomplished w/o paying for ($$ and/or stress-wise) a standalone.
Last edited by bc3tech; 01-09-2007 at 05:39 PM. Reason: to make the post NJHK-friendly
um no.... the DFMU will be outta the equation once the larger injectors go in.
even if you wanted to be a smartass, both are still cheaper than a) not tuning and blowing myself up or b) buying HPT
I said "doesn't seem very effective", meaning that it doesn't seem like it works that well, not at all.
The thing I don't understand is why you tell people how great the DFMU is but yet you're using something on top of it to achieve the performance and fuel consumption you're looking for. Also, if you could buy HP Tuners, you would or atleast you act like you would the way you were complaining that they wouldn't support your vehicle.
My ass isn't the smart portion of my body
I tell people that the DFMU works and does its purpose. it was PERFECT for 5psi or thereabouts because the precision of the 5 sliders on it was great. however now that i'm at 10psi at my altitude, it needs to be more precise of a tune. Search anywhere i hang out regularly and you'll see that i've told ppl the DFMU works but i'd go w/ the new unichip setup (also piggyback) or SMT-6 (kind of a hybrid to my understanding) if i were to get the speedmafia kit now (they didn't have the unichip when i got it).
i'm using something instead of it. not on top of it.
i reference HPT as example, not as what i'd get. if i said SCT Livewire nobody'd know WTF i was talking about. would "ECM programmer" make you happy? i'll edit my post when i'm done here.
#36
bugger off man, it's your fault you made the sweeping generality about piggybacks, not mine.
I said you would buy HP Tuners because of the way you were acting when HP Tuners didn't want to support your computer. To me, someone who is willing to go on every forum and post up a link to vote evidentally wants to use their product and wants that company to support their application so they can use that product. If I'm wrong, sue me but thats what you were implying by doing so.
You're saying you're using something instead of it, not on top of it...so are you using the SAFC alone or are you using both the SAFC and DFMU? Which is it?
And the "bugger off" comment, I didn't make you reply, you did it on your own. Also, I never said that they wouldn't work, I said they wouldn't work PROPERLY but go ahead and do what you want to your car and say what you want as far as how great it's working...doesn't bother me one bit.
#37
Step 1) Install DFMU and attempt tuning, realize not as precise as need be
Step 2) investigate alternatives, find others that have installed and document installation of SAFC-II on the 2.2
Step 3) Install SAFC-II on 2.2 and see how she works, with DFMU 0'd out and unplugged
Step 4) Realize SAFC-II does in fact alter the AFR to be richer, just not rich enough due to stock injector size - Redline (32#) injectors on standby
Step 5) Connect DFMU back up so car doesn't blow while waiting for warm weather to install new injectors
Step 6) bitch slap NJHK for saying piggybacks don't work on the 2.2L
#38
#39
thanks teacher... wtf do you think I think it is?
and clearly you didn't keep up on the "**** HPT, go vote on SCT's website because they're not pompous asses" comments i made shortly thereafter. even on your forum... wow.
ok let me slow this down for ya, corky...
they work entirely properly... wtf... and i will say what i observe not what i want - unlike some people. try something out or do some research before you tell people what they should or should not do w/ their cars, man.
I'd really love to see you bitch slap me. I mean, saying you're going to hurt me on an Internet forum a big difference in real life. Minnesotta isn't that far, so you can bring your super efficient pro-charged plastic mobile to Tennessee and lets see if you will really slap me. I didn't threaten you but if you want to say you're going to do some type of action like that, I'd really like to see you do it.
Little do you know that I've used an SAFC on a ******* 2.2 L61 on MY car at one point...so before you tell me what to research on, know my background and know who you're talking to, ok buddy?
So now go ahead and bitch and moan that I said that something won't work and that the big bad warewolf is being mean to you.
#42
I kept up with the **** HP Tuners but I'm talking about BEFORE hand when you all up their ass every 5 minutes with a post and YOU and YOUR actions almost totally turned HP Tuners away from the Deltas...so good job!
would that 2.2 l61 be the infamous sunfire i've heard about?
you are too powerful and have now made me cry so i'm going to leave everybody must concede to NJHK's uber-knowledge of all things ecotec...
#43
Oh yes, I'm talking about the "infamous" sunfire...problem?
#44
wow this is unbeleiveable. Do me a favor, do a search for posts made by NJHK. 95% of the time, they are the most informative, unbiased awnsers i have ever seen. Him and Halfcent are the best things to ever happen to my Pursuit. I'll take they're advice before I start to believe your piggyback set up.
#45
he never has clamed to know all but he does his best to help us when he can, more then i've seen you you do. so if your going to keep calling out members who contrubute more then you, please take that plastic caskit back to the redline froums.
#47
Pursuit, I really appreciate compliments.
#48
no prob man.
BYW Piggy backs dont work because the evil GM engineiers(sp?) thought it would be funny to give the 2.2 fort knox for a ecu. lol thats probably not really why but im sure NJHK has a better explination
#49
So if i plugged in one of those controllers my ecu would be like "WTF i dont think so!"??
Edit; I looked up AFC's and it seems like Apexi is like the only company making them, is that right?
#50
and for the rest of you that don't think they work....
http://s92.photobucket.com/albums/l2...nt=SAFC002.flv
http://s92.photobucket.com/albums/l2...nt=SAFC001.flv
this thread makes me laugh.
