Any questions about what things are.....
I am starting this thread because I have some things i don't know what they are. I've read through the forums and I can't find anyone else asking these questions, so if you have a question about what something is or where it goes, post it here.....
Now for my question, I have a second smaller plastic tube that used to run off of my stock airbox...anyone know what it is/does?
Thanks yall, I feel dumb now...
Did it look like this?
that's the SAI tube
Yeah, not all 07's have one. I have an 07 2.2L, and I don't. I bought my car in February, with 10 miles on it, so maybe it does have something to do with the production date.
they took 1 cat and split up it's job into 2 different cats.
car still puts out the same numbers...
cali, ny, and a few other states.
unless your car was special ordered by yourself or by your dealer, you have this.
if the dealer just requested 10 Cobalt LS's with automatics, good chance they got them with SAI b/c the dealers trade alot.
but if the dealer wanted 5 Cobalt LS's with XM and lets say..Onstar..and they were not in a "Cali Emmisions" state, then good chance they Don't have SAI
pretty much luck of the draw for the consumer. its not a big deal, SAI makes no difference with HP, it only runs on a cold startup to help lower emmisions while you idle the engine, warming the car.
enough with the 2 cats...its not any more restrictive than 1 cat.
Yep that was it....crapola
dude yep that was it in the picture. I was hoping that wasn't SAI, crap, I was praying it was a second tube to run to the A/C. Well wait a minute, I have 1 catalytic in mine, and I live in Vegas. I'll do some digging and find out if any of you don't know, all SAI does (as far as I can tell) is increase volume of air going out by diluting the exhaust with fresh air, therefore lowering the numbers that the o2 sensor reads. I'll have to do a lot of digging but, in theory, if you replaced your computer with a non SAI computer, and removed the SAI related stuff in your car, you could go without it as long as its not california. the non SAI cpu would not even register anything missing if it didn't know it was supposed to be there in the first place. if that would work then you could replace your headers and whatnot, and remove that crap out of your car and lose some weight if this makes sense, what's ur guys's 2 cents?
what do you mean "enough"? i havent even started talking about em.....it might be because your relatively new, but im a strong believer that removing a cat is only good for 1-2hp, if that...im aware they dont restrict to any noticeable degree...soo uhh...care to explain why your jumping on my back?
SAI flushes extra air into the exhaust manifold during a cold start to help eliminate and dilute leftover gasses. it is usually only turned on for 15-120 seconds and then clicks off. if you follow that tube it will go down in front of your engine where there is a pump and then back around and behind to the exhaust manifold.
