Anyone that has added the SS exhaust.....
Old 06-28-2007, 01:07 PM
slowion2's Avatar
the stock 2.2 manifold is so restrictive that even polishing it wouldn't help out a whole lot. Unless that is the ones with air injection are an improved design. your best bet would be to hold out for a header that works with your configuration, or at worst get your extrude honed. there are angles and areas that you will not be able to reach with a grinder or flap wheel on a rotary extension, but extrude honing will get it all for you.
at this point though, the cost is going to negate the appeal of running an lsj manifold anyway, so save for a better designed unit.
Old 06-28-2007, 04:30 PM
sugardaddy2885's Avatar
Originally Posted by tonio5555
What did you use to polish it smooth? I have an 06 with SAI so right now there are no aftermarket header options for me, I can't even go LSJ. So I'm considering polishing and smoothing my stock manifold. I thought about having it custom extrude honed like the GMPP manifold but that can be pricey.
Polishing it wouldnt do much good for it because the collector at the end is so small. It be extremely hard to get anything inside it to polish the inside. The ss manifold had a larger collector on it which made it easy to reach inside the whole thing.
RaginChopsuey
10-27-2015 01:27 PM
brandon04
10-21-2015 07:04 AM
dennis69
10-20-2015 04:49 PM
allpro666
09-24-2015 04:42 PM
dieGone
09-23-2015 10:20 AM
Quick Reply: Anyone that has added the SS exhaust.....
