auto trans. upgrade
auto trans. upgrade
I was wonderin what a automatic transmission interceptor did there one made by auto trans if anyone has any insight on what it does for performance and what its main purpose is ur advice is appreciated and also will it void my warranty
It increases line pressure which will result in stronger and more efficient shifts into gears. It will also cause more of a jerking going into gears because of the line pressure being raised. It is very adjustable and easy to use. I've had it for a long time, no problems what so ever.
If you need pictures of it and where it installs, let me know.
Originally Posted by CobaltCowboy
did you do the install yourself and will this allow the trans to shift faster?
Yes, it will shift faster and you won't have those sloppy stock shifts anymore.
Originally Posted by HackAbuse
Can someone make a how-to on this? Where can i get one of these?
dude you rock. love the sig, btw.
Check out the forum if you want...some nice people and good info.
Originally Posted by hondakiller
im sure they will come out with one for our tranny eventually
