Base Model Sleeper build (long time lurker)
Old 02-05-2016 | 06:01 PM
jdbaugh1's Avatar
First of all I want to comment on what a great community y'all have here. I referenced this site numerous times while planning and doing my build. I have a base model 2006 LS which I have always enjoyed even before putting the M62 supercharger on it. Now that I have started modding I have become addicted. I have decided to share my build with y'all and following is a list of the main components that I swapped in.
Powertrain mods:
-M62 Supercharger (3.1" pulley)
-LSJ throttle body and intake manifold (Dual-pass intercooler)
-ZZP S3 heat exchanger
-650cc Bosch split-spray fuel injectors
-Magnaflow 2.5" cat-back
-ZZP 2.5" High flow cat
-KY Kevlar clutch, pressure plate, and slave cylinder
-Custom CAI
Suspension and bake mods:
-FE5 struts with YYZ springs
-FE5 Alloy front control arms with spherical CABS
-24 mm front sway bar
-Powell hardcore rear sway bar and under car rails
-Front slotted rotors with Hawk performance ceramic pads
-Powergrid end links
Interior mods:
-AEM analog wideband and boost gauge
-TWM short throw shifter
Up on stands and seats removed to install under car rails from Powell
Installing UCR
UCR Installed
Here the car is on jack stands utilizing the UCRs from Powell. The UCRs are great if you don't have a lift to get the car up in the air. Only have to use a jack once on each side and the Rails rest nicely in the jack stand's cradles.
On the left is my new Powergrid adjustable end links. On the right is the stocker
Here is a picture of the stock control arm bushing. Lots of play and this one is torn.
Spherical TCAB from powell on the latest TC FE5 control arm
Stock and new control arms
Sway bar comparison
Front cradle assembly with newly installed goodies.
Sleeper status
Old 02-05-2016 | 06:07 PM
Nice man lots of goodies on it she looks really good, might have to consider the powell rails
Old 02-05-2016 | 06:15 PM
ssyellowss's Avatar
Nice build! Part of me wishes I had kept my 2.2.
Old 02-05-2016 | 06:20 PM
Same here but I really wanted turbo, rpd,sunroof, rear disk brakes etc etc lol
Old 02-05-2016 | 06:37 PM
jdbaugh1's Avatar
If you jack your car up very much at all I would highly recommend them. Single point lift nub on each side so you only move the jack once. It also sits nicely in the jack-stand's cradle for a nice wide stable base that gives you more confidence when working underneath it.
Old 02-05-2016 | 06:43 PM
Well I have done most of the work on my car but if I need to replace stuff I'm screwed since my lift access ended
Old 02-05-2016 | 08:01 PM
ssyellowss's Avatar
All of my work has been on jack stands in a garage or driveway. I wasn't aware of those bars until now.
Old 02-05-2016 | 08:12 PM
I'm sure have been out for awhile just not alot of people have them
Old 02-05-2016 | 08:43 PM
Haven07's Avatar
I need those bars myself... Nice car!
Future mods?
Old 02-05-2016 | 08:56 PM
jdbaugh1's Avatar
I want to put a wider tire on it but I like the steelies for this build. If I put wider tires, with probably 17X8 wheels, then I'll upgrade the brakes. Upgraded disc in front to go with disc conversion in back so bias isn't way off but I'm not sure the best way to go about doing that.
But I might save that money and spend it on a Quaife LSD.
More urgantly I need a header, but I can't decide what type to get, as I'm still on the stocker.
Old 02-06-2016 | 08:06 PM
T-fog's Avatar
Welcome to the forum, A lot of good people and a lot of good info on here.
Looks like you know what your doing and shes off to a good start. keep it up man!
jdbaugh1 (02-07-2016)
Old 02-06-2016 | 08:18 PM
blueLNFftw's Avatar
Can you measure the length of the shaft for the end links?
Old 02-06-2016 | 08:54 PM
Dude nice job with all the powell stuff, its top notch. And welcome to the forum!
Old 02-06-2016 | 08:55 PM
Did you do anything for springs and shocks/struts?
Old 02-07-2016 | 08:09 AM
jdbaugh1's Avatar
Latest TC FE5 struts and Powell's YYZ springs (V.5 if I remember right) all around.
Old 02-07-2016 | 08:12 AM
jdbaugh1's Avatar
Yeah I will try to do that today. Measuring stud to stud is the best I can do as I would have to take it off to measure just the shaft.
Old 02-19-2016 | 03:21 AM
DSLaBuda's Avatar
Awesome build man. Is that Trifecta tuned or did you go the piggyback/standalone route?
Old 02-19-2016 | 08:09 AM
jdbaugh1's Avatar
Trifecta tuned
edacsac
02-12-2016 01:22 PM
JoeJoe228
02-08-2016 06:27 PM
kzak104
01-29-2016 07:23 PM
OrangeCoba
01-26-2016 11:31 AM
Bigslim
01-07-2016 08:10 PM
Quick Reply: Base Model Sleeper build (long time lurker)
