Boost -vs 2.2 eco!!! What will or won't it take?
then why did you say you broke camshafts and bent valves?
https://www.cobaltss.net/forums/show...8&postcount=60
Yellowshowbalt where is the retort, you can't get out of that one!
becouse everyone was screeming whats the damage. and i said it broke a cam becouse how the engine was sounding "but i never got in to the engine when i said that" so i realy dident know. but when i finaly got some time i pulled the cam cover and there was nothing wrong. so i did a compreshion test and they were 200 and droping to 160 and holding so that lead me to air is ging in but exhaust is not coming out the end.
so yes i did lie about the cam being broke. thats what i thault hapened. i said that before i ever looked at my car. sorry.
Either way he's still breakin stuff though. He's running super rich so his engine shouldn't blow... but he'll foul so many sets of spark plugs and go through cat after cat as well as totally caking his combustion chamber with carbon. He might as well of broken a camshaft and bent a few valves... would've been cheaper. cats aren't cheap and the rest of the damage will take it's own toll.
No body is arguing that yellow didn't rush into supercharging without learning what he needed to do.
BUT at the same time I think people are being a bit too harsh on him...I mean it's his own money..he's not pulling money out of your checking account to pay for new cats...
The fact is he posted here. He's going to get the information he needs along with peoples' opinions. If he can't deal with that then he should have bought a book on tuning and performance building rather than posting on a forum. Just the way life is. No matter what you're doing you're always going to have to deal with peoples' opinions.
however, wouldnt he be running super lean? extra air from a SC but no extra fuel due to a lack of tuning...
#37
if he was running stock injectors then he would be running super lean. but he's not. He could try getting some smaller injectors... but I watched his video of his a/f runs. He IS running lean(higher 14s was the highest I saw) at some points while he was on the gas. I'd bet my left nut that if he monitored knock that he's getting a good amount of it at several points.
#40
yeah the car will work it's way back to a 14.7 afr on it's own for idling and part throttle cruising with the 02 sensors, but the second you hit the throttle and go into PE, that's it <10:1 afr's (I tested something with the stage III PCM and 60's) car ran great part throttle and idled fine, but the second it went into boost it loaded up on so much fuel the engine would start breaking up.
#41
Um, Well, first, welcome to the site I guess.
Second, you are in for some bad times dude.
If you had read anything on this site before you started, you would have learned that there is no currently no ability to tune the ECM in the 2005 L61 Cobalts. So it doesn't matter which injectors you stick in there, you won't be able to modify their operation at all.
I guess I'll point you to some articles. First, read this:
http://www.year2032.com/ecotec.htm
Then, read this:
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/l61-turbo-super-forced-induction-information-thread-26325/
There is a new piggyback tuning product from AEM that should work with this car. It is your best bet. However, it has no ability to tune the transmission. You will still get a working a product, but the trans shifting will be harsh.
Then, read this:
#42
You cant do that, thats made for return style fuel systems. We run a returnless. Now if you wanna go and convert it and try it, go for it! but no one as of yet has posted a successful return style fuel system on the balt. Its really not hard, i think people are just too lazy to do it.
#43
go ahead and put your fuel pressure to 5psi and see what happens...
You're going to need more than that for these cars. The problem is our pcm isn't designed for boost, so as soon as you introduce it the map sensor, maf sensor, O2 sensors, etc. are going to go crazy. You need some way to intercept those signals so that the bcm doesn't know anything's been changed.
#44
Closed Loop will keep him alive.
The BCM has nothing to do with fuel enrichment or ignition timing.
The O2 sensors won't freak out because in power enrichment, it IGNORES the primary O2 sensor. The primary O2 sensor is only used for closed loop operation...other than that, it does nothing. In power enrichment, it ONLY meters with the air metering device(s).
Last thing, he was saying 5 PSI of boost pressure, not fuel pressure.
#45
the BCM does body functions , it has nothing to do with the motor running n/a boost or other wise , only part of the pcm it controls is the theft and tell the pcm not to allow the motor to run
people have been adding boost to car with computers since the 80's , and they were stupid computers with barely enough knowledge to do simple math , lol
just because the computer doesnt have a program in it set for boost doesnt mean its have major issues , there is always around something
#46
Exactly.
On the cobalts, the MAF sensor is the main air metering device. It's meant to measure air but the problem is that it can only read upwards of 5 volts and it relates to a certain fuel map in the computer because it's estimating how much air is coming in (or supposed to be coming in). It won't freak out but it will just be in accurate. I don't have experience with these cars specifically but I'd bet that it will start to dump fuel or pull timing.
meant to say pcm
he doesn't have something to keep him in PE all the time. Or would it do that automatically?
thought he was talking about fuel pressure. sry
do you even know anything about cars ? your post is idiotic
I've added a turbo to a naturally aspirated engine before using just a rising rate and a map clamp. Just seems these cars are a little more complicated than that. Possibly a maf translator would do some good, but I don't really have alot of experience with that.
And the fact that the pcm isn't programmed for boost is a decent issue. The fact that it's not set to read air pressures above 1 bar, fuel tables for n/a are COMPLETELY different from f/i(which isn't that hard to change, but he's not running a programmer), and same with the ignition tables.
computers are still stupid, they just have more capability now to check different aspects of the engine than they did in the 80s with obd 1
the point I was trying to make is even if he does get the a/f right with a 10:1 regulator there's going to be other complications. I just didn't say it very well and I apologize
#48
umm something it seems everyone forgot about...
what year balt do you have?
if you say 07 go do the happy dance and get HPtuned... if not.. get the AEM F/ic that looks good... and still if not.. there's a company thats developing a intake manifold and tuning combo for 2.2s that could be freakin sweet for you if it works as well as planned
dewd so do eye
dewd so do eye
#50
dewd so do eye
dewd so do eye
