boosted 2.2 revving uncontrollably
Old 07-27-2009, 12:03 AM
asherby85's Avatar
...posting for a friend...
Anyone have an idea why a 06 2.2 ion that's recently been boosted would rev uncontrollably when you start the car? It's running 42# injectors.
edit..he wanted me to add... spliced the injector wires ie used the pigtail harnes
Old 07-27-2009, 12:14 AM
Preston's Avatar
lol
like when you start it it just revs up like if it was floored?
Old 07-27-2009, 12:18 AM
Sizzle06's Avatar
Tune?
Old 07-27-2009, 12:22 AM
Preston's Avatar
If it wasn't tuned..it wouldn't do that i dont think. You would just smell the gas hardcore..i ran SS injectors for a minute un-tuned on my car. (we were doing tests to see if my tune loaded) and it bogged bad.
check the throttle body..might be stuck
Old 07-27-2009, 12:26 AM
elecblue06's Avatar
i can hear the TB plate open wen the car i put to the acc potion
and yes like its floored
i checked thr freaking harnessto make sure i ddnt somehhow tap the TB plug and unfortunately I didnt
we're at a los now EVERYTHING that could g wrong has gone wrong o fari jut want this kid car to be running i dont care if it doesnt run wel at tis point i just want it to drive under its own power
Old 07-27-2009, 12:31 AM
Preston's Avatar
umm can you borrow someones injectors? swap yours out and put there's in maybe you did wiring on injectors wrong?
stock tb?
Old 07-27-2009, 12:33 AM
HunterKiller89's Avatar
thats what happens when you put a LSJ TB on a 2.2/2.4 without rewiring the harness. I dont suppose you did that?
Old 07-27-2009, 02:08 AM
elecblue06's Avatar
nope.. stock 2.2 TB only thing was done to the harness is wired the 42 lb pigtails in place of the stock 24lb injectors.. it's freaking driving me nuts I thought somehow I spliced the power wire for the TB into a power for an injector so it was getting that somehow but i didn't ..
i wired it up just like yuou did in your how to lol
i appologize for all the typos before.. I was typing in the dark on my phone lol
Old 07-27-2009, 02:13 AM
mrsilent13's Avatar
i have never heard of such a thing...but if the wiring is good...i would say check the TB and make sure its hooked up correctly and that its not stuck open.
Old 07-27-2009, 02:38 AM
elecblue06's Avatar
oh and it's not a tune issue.. we tried it with the stock tune.. as well as the new tune.. both have the issue.. tb doens't look like it's stuck open i'm really at a loss here
hes checking the harness tomorrow I was going to do it but i might have to work.. he gets out at 3 I get out at 630 if i have to work
Old 07-27-2009, 03:18 AM
mrsilent13's Avatar
hey check the mass air sensor...that could be your problem
another thing it could be...is the idle control valve....is it in the TB? i dont know?
Old 07-27-2009, 03:35 AM
elecblue06's Avatar
thats the thing i don't get.. we cheacked the maf sensor.. it's the right way.. it's clean
he didn't mess with the TB prior to me installing things and I didn't mess with it at all either i thought about that though.. it's really pissing me off.. hows your car running thouhg silent?
Old 07-27-2009, 05:38 AM
our cars dont have an idle control valve. our idle is controlled directly by our TB blade
did you do any intake work too?
maybe a vacuum leak somewhere post TB?
take off the intake, and start the car (you'll throw a MAF code im sure), but watch the TB and see if it is open or if its mostly closed, like it should be
Old 07-27-2009, 09:10 AM
mrsilent13's Avatar
my car is running great...but lately ive been dealing with a dead battery every morning. i finally tackled it yesterday. i think i found the problem but i guess ill find out when i go out and start it and see if it starts or not
yes i figuered that...thats why i asked? u know just to make sure
Old 07-27-2009, 11:23 AM
elecblue06's Avatar
well we have the intake off now so when we put in the injectors again i'll look at it see what it's doing .. hopefully it's just something stupid
Old 07-27-2009, 11:36 AM
mrsilent13's Avatar
im sure it is something stupid...hopefully you find it...
bad connection somewhere maybe
Old 07-27-2009, 03:04 PM
elecblue06's Avatar
i hope it is .. this **** is REALLY annoying
Old 07-27-2009, 03:16 PM
PSHHH's Avatar
do we have a throttle position sensor? when i had a mustang mine went up and everytime id go to start it jumped right to 4k
Old 07-27-2009, 03:32 PM
elecblue06's Avatar
i dunno i think we do ... but i dunno where it is lol it could be on the gas pedal though lol so if something was knocked out of place it could screw things up lol
Old 07-27-2009, 04:19 PM
the TB has 2 throttle position sensors on board. one goes 0-5V as the throttle opens, and the other goes 5-0V as the throttle opens
Old 07-27-2009, 05:04 PM
mrsilent13's Avatar
well is the car throwing any codes at all?
Old 07-27-2009, 05:49 PM
shawn672's Avatar
i bet you a wire is touching the TB
happened with our 200sx, the car would rev uncontrollably when turned on because the battery wire was touching the TB
Old 07-27-2009, 09:33 PM
elecblue06's Avatar
well i still dunno what it is
when we put the stck injectord in it was fine..... 42s it revs we witched the wiring around and itg stil does it
what are you talking about with the wre touching the tb
Old 07-27-2009, 09:39 PM
Gene Culley's Avatar
Talking
You probably didn't get the injectors seated properly and air is getting in there. You would be able to tell by spraying carb cleaner around them when the engine is running.
Old 07-27-2009, 10:04 PM
shawn672's Avatar
if changing the injectors fixes the issue, then ignore me.
at first it sounded like an exposed wire touching the TB
Quick Reply: boosted 2.2 revving uncontrollably
