Bored at work Found some PN's for the 2.2
So once again I’m at work and bored looking for Cobalt Parts available and came up with this list. All the NAL parts are produced by GM performance. Also this list is based on the 2.2L because that’s what I have, if you are looking for 2.0 or 2.4 let me know. I get bored often.
VNM-M45359 Venom Intake manifold
NAL-12499679 complete 2.2l Ecotec
NAL-12499466 Complete S/C 2.0l
NAL-88958630 Ecotec alum. Race block, 3.4 bore, 8.7 deck height steel sleeves,mach. For o-ring, studs
NAL-88958620 4130 Billet steel crankshaft stroke 3.505
NAL-88958618 billet rods length 5.888
NAL-88958634 forged direct replacement pistons/rings
NAL-88958640 Ecotec CNC ported Head
NAL-88958632 Header Flange
NAL-88958638 Turbo Wastegate Adapter
NAL-88958614 Head gasket and o-ring kit
NAL-88958648 CAMS 268 duration@.50 int/ext,.464 lift, centerline is 232 degrees
NAL-88958611 Blank intake cam for custom grind
NAL-88958612 Blank Exhaust cam for custom grind
NAL-88958613 Adjustable cam Gears
NAL-88958615 Neutral Balance shaft set
NAL-88958629 Alum Intake Manifold for use with 75mm LS1 throttle body
NAL-88958633 .555 thick alum. Intake flange
NAL-12499351 Cobalt Exhaust Tip
MSD-6212 Programmable DIS 2
MSD-8913 Tach Adapter
AVM-21-531(R,B,C) AEM Intake
DCS-CSB2004 DC sports Front Strut Bar
DCS-SCS7033 DC sports Exhaust
MPE-16618 Magna Flow 2.2 Exhaust
ESP-5765C3D Eagle Rods 5.765
SUM-EP-55083-L Front Left cross drilled Base,ls,lt
SUM-EP-55083-R Front Right cross drilled Base,ls,lt
EDL-70214 Edelbrock Cobalt Specific Nitrous wet kit
PSM-88-1475 Pacesetter Exhaust
PSM-70-1272 Pacesetter Black Coated header
PSM-72c1272 Pacesetter Armor Coated Header
KNN-33-2311 KNN Drop in filter element
FIZ-198281 Findanza Alum. Flywheel
FIX-229101 Findanza Flexplate
JSP-CFT512 JSP OE 4dr Carbon Fiber Trunk
JSP-CFH061 JSP OE Carbon Fiber Hood
EAC-GMK1010 Exedy Clutch
EBC-DP21660 EBC Green Stuff Front Pads
If your interested in any parts, some may not be on our system yet but
I can get it all let me know if you want me to do any research for
Something.
ENJOY
Something.
ENJOY
yeah i went on their website a few minutes ago and saw it it looks awesome but wont give huge gains until forced induction, i will pick one up either way though, that few hp could be the difference between winning and losing
