Calling on you 2.2 guys for help
Alright my car is pissing me off. heres the deal, everytime i get gas (and ONLY when i get gas) after i get done pumping and get in my car to start it,it wont ******* start, the starter is well uhh starting, it finally starts to fire, then my rpm is going crazy 1 to 3 up and down and it will keep doing that till i give it some gas, then it acts fine. bsically it sounds like my car has a big cam the i give it a little gas and it goes back to normal and wont do it again until i fill up. which leaves me to believe it has something to do with pressureization* then later here recently my car is telling me to service airbags? and service traction control, and it turned tracton control off. i mean wtf. my car only has 27000 miles on it and i bought it brand new, its making me wonder how its gonna be at 75000 miles if its already acting up now. ill end up taking it to beaty chevrolet soon i guess eventhough money is tight, i gotta have a car. just wanting your opinions.
thanks in advance...
hell no its like a so many year or mile warranty and i already passed the years. and last time i went in for calipers sticking and those ******* kept trying to screw me over. you know how they are at the dealership. if your under warranty they try to make up other excuses for the problems. they tried to tell me that my braking problem( calipers sticking) was because my aftermarket rims.lol
yeah, it just sucks man. i mean i have to depend on this car to get me places and its starting to worry me, money is tight and i cant be dumping it into this car. i start college on the 29, i need a dependable ride.
I wonder if someone put something in ur tank and when you put gas in the tank the pressure from the gas going into there if its pushing something down to the bottom of the tank where the main fuel line is located at (someone chime in if Im wrong here)
i do have quite a bit of haters.lol but i never leave my car anywhere around this small town for that reason. they probably wont chime in until tomorrow. haha its a little late
If you got haters out there I would maybe look into seeing if you can drain your tank and see if theres somewhere on it that you can look down into the tank and see if theres something in there
Check your evap solinoid, might be stuck open, its a 20ish dollar part and a quick fix, or it your mostly stock (no 2.4IM or CAI) the dealership should fix it under the 100k 5yr powertrain etc, and if they don't call GM customer care and start asking questions/complaining there are plenty of people who have got stuff done dealers didn't want to do, but legally have to.
the only performance mods i have is a ingen cold air intake and i have a shitty muffler, thats it. the maf sensor wouldnt be a problem would it? i mean the thing is it ONLY does it when i get gas.
Put the engine back to stock and drive it. The intake may be part of your problem. If not leave it stock and take it in. '07 and up GM vehicals have a limited 100,000 mile powertrain warranty.
But for the being hasseled just throw your stocker back on, and if they give you **** call GM customer care its amazing what will get done when you talk to the right ppl
Ill have to check on that, although i dont have a cel. wont get to take it to dealer as i wanted today but im going to take it to a shop at my dads work, those guys are quite car savvy.
I has a similar problem. Check your intake for leaks, that was my problem. Also you should still be covered under the powertrain warranty which is 5 year or 100,000 miles. Hope this helps.
And just because you don't have a CEL doesn't mean its not broken, if the sensor that is supposed to throw the CEL is not functioning then no CEL.
Has your info center thing ever said check gas cap?
That would be an indication of a P0455 large evap leak. This seems more like a stuck open purge valve, (P0496 I think) Allowing fuel vapor to be pushed through the lines and into the intake during refueling.
YOU GUYS WERE RIGHT its the evap purge solenoid sensor! the guy at my dads work shop plugged the scanner in and it coded. going to pick up the part (or order it) tomorow. thanks for your help guys! im so excited this is it instead of something more serious!
