Cam ?
#151
cams have nothing to do with piston movement.....it has to do with valve movement, diff cam profiles will determine how much and how long and when a valve is depressed in relation to the pistons movement throughout the strokes...diff cams make diff power in diff rpm ranges.....
#156
honestly if you wanna make big NA power, go with a more aggressive cam grind and try to raise the redline to around 7.2k or so and get new valve springs and get a new light weight crank shaftt and have it rebalance to like 9k rpms.... then with nitrous your power range will be really igh up top at 7k rpms..
#157
my goal is 250 whp, With intake manifold,throttle body,header downpipe,pulley,exhaust,intake,stage 1 cams a tune and a 75 wet shot i should be clocking aorund there???
Sign_Something
13
09-26-2015 11:44 AM
