Cam up grade
Cam up grade
Hi guys need some help i have a 2.2 hhr 2008 i want to install a cam.do anyone know what will work in my car & where i can get one from ? i install a superchanger a year ago
I'm assuming you're running an M62 Supercharger, correct?
As far as the which camshaft you should get, check out Turbo Tech Racing and see what they have for your particular year. Also what are you tuning with? Reason for asking is because whenever you do change your cam profile, its essential to accommodate the changes.
Holy grammar and spell check. Read over your own typing before you post so that others can understand it. And about cams, you have the 32 bit computer L61 motor which is incapable of accepting a direct new bolt in cam because of the cam position sensor. Just like the 2007+ cobalts.
Nope no off the shelf cam you would have to by the cam and then find someone even willing to press the cam sensor on. In 07 GM put the cam sensors on the cam. 00-06 L61s are the only ones with readily off the shelf cams.
thanks i will call GM performanace today i have a part no, with a cam would my car still be ok for 6 or 8 hr trips?
drove 12hrs straight from Phoinex to San Antonio with no problems on comp stage 2s. Then another 2 and half from SA to Houston so yes. I took 4 hr and 6hr trips across Texas al the time with stage 2s with no issues.
thanks for the post because i drive my car on 5 to 6 hr trips. how is your idle on your car ? my wife love this car and if i get it sounding to bad she go crazy on me. is this the part no. for comp cam 113150 that you are using ? even though this cam want work on my 08 hhr 2.2 im going to send the specs. off comp cam to crower cam , if i cant fine one . they can regrind my cam or build me one
Idle is a little louder deffinatly lopey. My car doesn't like cold starts it will throw a random cyclinder misfire code on really cold days then once it heats up no issues. My ex girlfriend had no issues driving the car, so driveablility wan't horribly affected.
thanks, was the part no from your comp cam 113150 im try to pick from that one or 113250 ? did it help your hp alot ? and was the cam for mid range or top end ? i no this sound crazy is the sound real noticeable outside the car
thanks for your the help i'm getting my cams regrind by crower cams, so do i need to change my belt tensioner i'm put on a 2.7 pulley or will mine be ok ? have 2008 HHR 2.2
Sign_Something
13
09-26-2015 11:44 AM
