cams for 2.2
cams for 2.2
i wanted to get new cams for my car and i found a nice set on CED and i was just wondering if i were to put those on what else would i need to do to the engine to make sure it works and doesnt blow up
CED sells ground cams? I thought they were just blanks?
You might want to look at www.TurboTechRacing.com at the Comp Cams, they are the #1 seller for the ecotec and come in 5 different grinds to meet your building needs.
The GM Performance Cams listed are for race only engines and not meant for replacement cams.
From their site:
Note:
The GM Performance Parts ECOtec cam set (88958648 set or 88958636/7 individually) is an aggressive race cam. They are not stock-replacement cams; they require upgraded valve springs and retainers. These cams were designed for a race motor, using the 06 L61 as the starting point. The cams will not fit the 2.4L LE5 head and will not work with the stock ECM or lifters. They physically fit the 2.0L LSJ head, but the vacuum pump / cam sensor will not work in a stock engine.
From their site:
Note:
I beg you please do more homework before you blow up your car. You can PM myself or halfcent any questions you may have and Myself or Halfcent should know the answer. What year is your car BTW?
the car is an 08 and thats why im asking so many questions i really would rather not blow the car up. so i was looking and im thinking of going with the comp stage 1 cams in spring time now is there anything else i have to do to not blow the car up to make them work?
Can we clear something up because I guess I missed something in the last few weeks/months...if you have an 08, how can you get cams and I (07 LS) can't...I know in 07 they added the Cam Position Sensor, so did they change the 08 in some way that it will work, or does SportRedLT not know about that?
You got to want for company's to make cams and all that for the 08 models, there brand new and probably have different setups than 05-07. I own a 06 and i'm getting cams installed this Christmas.
2007-08 are the same with the extra CPS
