can I only use injen filters?
don't cheap out on your air filter. that's what stops things from getting into your engine. suppose it falls apart, and you start sucking things into your engine. are you going to look back and think how happy you were you saved that 20-30 dollars? If you're going to do it, do it right. If you can't afford a quality filter, don't put the intake on until you can.
i don't know if you have a parts america close by but they carry the aem dry flow filter on hand. i just don't know what kind of autoparts stores you got down there.
i have a spectre filter from Autozone and i check it about every 2 weeks to see if its doing fine. i've had it on for about 6 months now. seems to be holding up just fine =]
its not the structural integrity of the filter us big name company fanbois are worried about. it the actual filtration of the no name vs. the respectable companies.
we're worried about the function of the filter that you can't see at all, and how much **** it keeps from your engine.
that being said, i would never put no name on the end of my intake. mostly for the piece of mind that knowing i have a decent filter brings me.
