cant pass up an ebay deal like this...
yeah i have a CAC reader at the house lol...but goto this thread....page 3 post #38 it has what you want and it's in how to format
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/2-4intake-mani-117137/
it's still up....that particular auction ended...here is the new link
http://cgi.ebay.com/ebaymotors/chevy...m280236120173&
What do you think of this?
http://cgi.ebay.com/ebaymotors/TURBO...8972QQtcZphoto
Last edited by ChevyRockstar; 06-18-2008 at 07:29 PM. Reason: Automerged Doublepost
if the one in the picture is what your getting it WILL NOT work for a few reasons.
1.the headers themselves are not bent enough to clear firewall
2. Look at the flange after the DP. oops! its vertical not horizontal like the cobalts.
NOOOO , that has MAYBE 1/3 the parts you actually need for FI, expect to pay 4 times the amount of the kit AT LEAST to make it actually work.
just buy the hahn kit
LMAO "piping can be used for any car. toyota mazda mitsu ford dodge . etc..."
tht was on the site for the "turbo kit"
will it bolt up to the rest of stock exhaust?
Last edited by originaladrian; 06-18-2008 at 07:35 PM. Reason: Automerged Doublepost
The turbo was just a
you could get a garret turbo kit but you can also make one of your own and probably cheaper if you know where to look for the parts since vulcan here is the link http://www.vulcanturbo.com/GMmanifolds.html and im also getting a trust intercooler and piping for it since im in japan. there are many deals that go on ebay but do your research first before spending the money especially for headers. you wouldnt want that over heating and craking on you.
that kit is no good, you can use maybe...a few parts from it, the Ic the piping, the lines, etc, turbo is useless, wastegate is useless...everything else is salvageable...and as for the header, it looks like it might work, not usre on the flex ip loation, might hit the cars front beam...you might be able to flex it for a tight fit, some header wrap in that section only will help with rattles fromt oucgin, the flange can easilty be cut rotated, and welded back, for 100 buck it could be worth it...you would of spent like 150 in the end...dependingon who does ur welding, i got a buddy who will do my **** for 50 bucks, and waranty for life from leaks..well his shop will
