catch can
#51
i swapped my valve cover for a painted one yest and it was all still fine
here lol, not too hard to find
http://cgi.ebay.com/ebaymotors/polis...Q5fAccessories
http://cgi.ebay.com/ebaymotors/S-G-O...Q5fCarQ5fParts
here is the one i have (they changed and included the price of shipping...same i paid total though), they make it in mult colors
http://cgi.ebay.com/ebaymotors/IS300...Q5fAccessories
#52
well thats diff haha, your putting stresses on the car and mounts of things more then any of us will
#54
looks good, have u consider'/d a bigger front pipe for the intake, instead of the 2.75" pipe that turn into 3" on the MAF pipe? that could be a restriction for you, might of been ok for stock, but have stgII Cams..u should look into making a replacement in 3" see if that helps
#60
and about the black hose, i know, this is what came with it...waiting for payday haha
#61
okay i might be going crazy but have any of you guys seen the design of our intake manifolds? the air runs to the back of the intake mani then down the up into the intake ports.
i can't for the life of me see how oil would miraculously get all the way through the intake manifold then into the engine.
maybe its just my pointless logic kicking in but i can't see the use for one of these.
#62
#63
but they didn't.
not to mention you'd think a car company that has been around since 1911 would have enough experience with motors to know that they're doing it wrong and that someone who's in his 20s knows more than they do.
#64
you really think if the slight buildup was a problem chevrolet would have devised a catch can themselves? i'm sorry to say it but i think they have a tiny bit more experience with cars than you do. if they saw that oil buildup would be a problem i'm almost dead certain that they would have added a catch can themselves.
but they didn't.
but they didn't.
Why would the oil pressure be too high? What would cause that situation?
#65
but they didn't.
but they didn't.
#67
also, if you switch intake manis, or switch to boosted it all changes and you need to be able to combat it...think of it as a 25$ reallllllly cheap insurance for "just in case" that one time something wrong happens
#70
yup yup, every car ive taken the intake mani on (4 cobalts) have all had oil in the intake ports
#71
and no, the v8 shouldnt, they designed it for the way it rolled off the lot, but neither JN2 nor I run ANYWHERE near stock AT ALL and chevy did not plan for what i have done, so i have to. But if a v8 tossed some high compression and cams in the mix, or a blower, yes, i believe it would be a decent idea (although I do not know the v8 world to know if they would even need one in their application)
I dont think i have EVER seen a stock car to use one or be equiped with one. its not intended for that, reputable companies make them and designed them for aftermarket and non stock applications as a way to make sure your car does not "inhale" extra oil...
and seriously...i dont understand why this is such a complicated idea??? im not saying we all need one, go ahead and NEVER buy one. but im saying for those of us drastically not stock, its cheap insurance for the money we have invested in the car. If this happened to my car stock i would take it tot he dealer under warranty....but i dont have one of those anymore....
#72
I would be just pleased with a PERFECTLY clean catch can, that means the rest of my engine is doing its job, but if somethign goes wrong, then at least im protected
good deal, which one did you end up getting???
i just gotta figure out where im gonna mount it......i have the GMPP intake (SRI) so i gotta play around under the hood and make some room
#73
it does come with a secondary bracket you could bolt to the fire wall then bolt the one im using to it! put it right back there next to the strut tower behind the valve cover.
#74
i hope so its tight under there i have SAI as well FML lol
that could work but i dk if i wanna run a hose that long
#75
ya, that is pretty long, other option is to put it in the front and bolt it around the intake area to the front where the hood latches and such (in front hahahaa)
