CEL, keeps coming on...HELP!!
Old 06-23-2006, 12:16 AM
TWIZTED 2.2's Avatar
Angry CEL, keeps coming on...HELP!!
So i bought a Weapon-R Intake last week. No problems, Tues I extended it to down through to bumper.(Cold Air) No problems, It rains like a bitch Wed afternoon, and ever since check engine lite wont go away.
HELP!!
Old 06-23-2006, 12:20 AM
KeystoneSC's Avatar
My guess is that your filter is clogged, and not feeding enough air to the system. And not just by getting it wet...but by the road debris etc that would stick because of it. You might want to pull it, give it a thorough cleaning and try again.
Just my $.02
Old 06-23-2006, 12:22 AM
Just my $.02
i did pull it, and there was no debris, but it was dripping water
Old 06-23-2006, 12:27 AM
Mrmaasta's Avatar
Dripping can't be good.
Old 06-23-2006, 12:30 AM
Mrmaasta's Avatar
Put stock back on and get that CEL checked out.
But the car runs ok right?
Old 06-23-2006, 12:31 AM
KeystoneSC's Avatar
That explains the poor airflow AND the CEL! For example, put a t-shirt up against your face and breath...then try again when the t-shirt is wet. Same thing happens with your filter.
Dry it out thoroughly, clean it according to Weapon R's guidelines and try again.
And unless you want to continue doing this every time it rains, I'd either back it up under the wheel well some or fabricate a shield to deflect the rain.
Old 06-23-2006, 02:27 AM
it runs fine until i punch it.. but i only did that once..
as for drying it out.. ill try that tomorrow..what would you recomend to dry it out
Old 06-23-2006, 04:03 AM
bump..
Old 06-23-2006, 12:25 PM
Get low
biohazard's Avatar
air
Old 06-24-2006, 05:01 AM
In a 2.2 auto trans, is there much difference in the CAI and the SRI. Because i didnt start havin the CEL problems until i extended the SR.
Old 06-24-2006, 09:53 AM
BlueThunder2006's Avatar
From what I'm told, the SRI will improve your throttle response without the water problems, while the full CAI is better over-all for performance but with some risk of water problems. I don't think there's a 'huge' difference, though.
I have a 2.2 auto as well and I'm still debating whether or not to install an intake. IF I do, I'll likely go with the Injen set up as an SRI. Less headaches overall, IMO.
Old 06-24-2006, 11:21 AM
CEL Code from Auto Zone : Was *dun dun nu na sounds or w/e*
P0171 1 of 2
P0171 2 of 2
The PCM has determined that during testing
the fuel system for bank 1 was too lean,
( Bank 1 IDs the location of Cylinder #1,
While Bank 2 Identifies the Cylinders on the opposite bank)
Old 06-24-2006, 11:26 AM
bc the filter isnt wet any more and i put it back to a SRI until i can shorten the CAI bc its too close to the bumper which is going to lead to wet ness i need to fix something that is going to feed the air straight to the filter without lettin water to it..
I was drivnin on the Highway and my Coolant was at 186 , but i hit the offramp to come home, and while i was sittin at the light it climb all the way to 213
Old 06-26-2006, 01:41 PM
damon14's Avatar
Yea I have no idea of what to do either...Someone responded that I could pull the positive from the battery for about 20 minutes and then connect it back, but I highly doubt that this would work..What else is ther to do? Any help...Anybody...???
Old 06-26-2006, 01:49 PM
Get low
biohazard's Avatar
pull the neg for 5 mins
Old 06-27-2006, 08:50 PM
bykryder83's Avatar
my cel light is on i pulled the code and it is p103 lean code i have the aem cai...is any one else havin this problem
Old 06-27-2006, 11:17 PM
tiny's Avatar
get an air bypass valve for your intake
unhook the neg terminal of your battery, press the brake pedal for 15 sec to get all current out of your system
id guess oil from the filter got on the air flow sensor
Old 06-27-2006, 11:30 PM
CobaltCoupeCrazy's Avatar
I have an Injen installed as a CAI and I have driven in FLOODING DOWNPOURS with no problems at all.
Also. the 2.2L's will get really warm even into the 220's; expect it.
I don't know what kind of filter Weapon R uses but air is never a good idea. Whether it's paper, cotton or the dryflow, compressed air can and will blow holes in the filter even if you can't see them. Place the filter near an air register in the house to aid in drying.
I have heard that there is a difference in the CAI vs SRI as below:
CAI: More Power Overall and toward the upper end with delayed response on the bottom end
SRI: Better Throttle Response with lower power gains but much earlier in RPM's.
I have the CAI and I do know that the delayed throttle response keeps me from spinning my tires as easily and lets me get traction and as the revs increase the power really comes on strong. I like playing catch-up.
The local parts store can erase the CEL's also.
Old 06-28-2006, 12:13 AM
bykryder83's Avatar
the filter is a dryflow i checked the maf sensor andit was ok what do u mean air bypass valve
Old 07-03-2006, 05:25 PM
thekeebler_elf's Avatar
Sounds like the exact same problem that I had. It turned out to bee the mass airflow sensor. The Sensor still performed like it should, but the PCM still read a problem. Replace the Airflow sensor. thats the only action that remedied the problem for me.
Old 07-03-2006, 06:31 PM
hectanooga's Avatar
If the light is still on, go to Autozone, (or any equivalent auto parts store that rents out tools) and rent a code reader. Find out what the CEL is on for. It could be something totally unrelated.
Old 07-03-2006, 10:19 PM
CEL is no longer on.. thanks though
Close this thread.. !
Old 07-04-2006, 12:42 AM
IonNinja's Avatar
how in the hell does your filter get wet wheres its located?
Old 07-04-2006, 12:50 AM
I brought it back to a SRI.. i had it extended to the bumper.. im going to exstend it again i just need to get the pipe cut
Old 07-04-2006, 12:51 AM
NightriderCobaltSS's Avatar
I have a K&N and since has that plastic sheiding under that car which does a good job of protecting the filter. I mean with a CAI ud have to submerse it to get it wet. but i am no expert my any means.
Quick Reply: CEL, keeps coming on...HELP!!
