check engine light
check engine light
just a quick ? oil needs to be changed, its at 4% ......
display thinngy says change engn oil,
will that throw a check engine light?
also how do you re set that display oil % bs?
thanks
thanks
You can also reset the oil percentage by turning the key to the on position and have the DIC display your oil percentage. Press the gas pedal in 3 times to the floor and it will flash and reset to 100%.
thats like 7k miles on an oil change. please tell me youre using synthetic at least.
ya its synthetic...and cracked i guess because of trying to get it off the person that had it b4 me did not put oil on the o ring on the cap so it stuck...and i bought the car at 15% so i just got around to it...
