Cold Air Intake Problems
I put a custom cold air intake on my 07 LT. I ran it about a .5 mile and the traction control disabled light came on and it blinked up service traction control. I continued out the road about another mile and my car went into "Power Reduction Mode." I put the stock intake back on and it all goes away. Any suggestions?
And buying an intake is a simple solution, i'd recommend the KN or Injen stay far far away from the Weapon R (made the mistake, it works but the fitment sucks a big one)
And TTR is a good company only heard good things about them
I tried 2 different ones in it. and still no luck. but i runs good with what ive got on it. so until i can get an injen or something ill just hang out with what i got.
this is pretty much what is happeneing with mine (except mine is having trouble statring after every fill up) but i have a ingen cai maybe i should check for leaks...maybe the maf sensor too, i thought there was only one way to put it in.lol
mine just started saying service traction control. maybe my probles are a combination of things. and if his problem is like mine its not coding
And yes there is a correct way to put the maf in, and a wrong way.
OP I'd clean your maf and double check the orientation. Does your maf adapter change the intake tube size?
