compression test
compression test
most of you have seen my troubles in my buiild thread...
but tonight im going to pick up a compression tester at schucks (only 25$) and test the car to make sure im building compression...what should i be looking for as far as readings?? whats normal?
anything i need to know special about our cars before i go do this tonight?
What year is your car? i can look on alldata
All alldata says is no cylinder reading should be less than 689kpa or 100 psi
Dumb question cuz I've never had to do it or known someone that has, but how do you check compression? I think I might have a problem, but I don't wanna take it to the dealer and have it gone for a week or however long they think they need to make me wait
you buy a tester (mine was 30$ at schucks), pull a spark plug, instert the tester, pull the fuel injector fuse so you dont get fuel, and turn it over 3-5 times and read the compression, do this to all cyl and check the numb, all 2.2l i have done show between 170-190psi...and i think they are supposed to be within 15psi of each other. if it shows low, then drop a few drops oil and try again, if that fixes it then you have worn rings or cyl walls. if it doesnt then head gasket or valve problems
well mines a 2.0, not 2.2 so i don't know if my compression numbers would be the same, but I'll check into that tomo since I have the day off. Thanks for the info...I keep smellin antifreeze from my exhaust, so i hope this helps me track down the issue
Honestly, that's what I'm hoping. It's alooooot easier than replacing piston rings or valvetrain components. But, can't hurt to double check my compression and make sure. If i do a head gasket myself and have to take it back to the dealer later for something, are they gonna know? and would it void out my warranty?
would they know?? i suppose they might if you use diff bolts (aftermarket not gm head bolts) or a none gm head gasket...and if they did im sure it would void the warranty
To do a proper compression test you have to remove all the spark plugs, disable the ignition and fuel system, insert the compression gauge in one spark plug hole at a time, and crank the engine at least 4 cycles each test. Having all the spark plugs out allows the starter to crank the engine for the test -- it doesn't have to "fight" the non-tested cylinder's compression during the test.
