Coolant temp
Old 07-12-2008 | 01:51 PM
MP81's Avatar
Coolant temp
What's the typical coolant temp these cars run around with?
Old 07-12-2008 | 01:56 PM
ls1fbody's Avatar
Haz l33t wheelz.
180.
Spanky's Monkey's Avatar
i see 213 in hot ass you ain't going no where traffic and 194 when i'm crusin real easy like.
Old 07-12-2008 | 01:58 PM
MP81's Avatar
All right.
I think I hit around 213 while cruising around Woodward waiting for some of my friends. About 85 and humid.
I was worried because I'm used to my Camaro which rarely hits 160.
Old 07-12-2008 | 01:59 PM
ls1fbody's Avatar
Haz l33t wheelz.
my bad, this is the 2.2 area. i don't think it should be much different however.
damn i need to start looking at the Forum area.....
Old 07-12-2008 | 02:00 PM
D4u2s0t's Avatar
search "coolant temp" in the advanced search, and search the titles only. you'll find a shitload of answers.
basically anything under 230 is considered normal
my 2.2 ran an average of about 10 degrees hotter than the 2.0 does.
Old 07-12-2008 | 02:02 PM
ls1fbody's Avatar
Haz l33t wheelz.
ok then, 190 should be about right, which is what they're running.
Old 07-12-2008 | 02:16 PM
yep.
MP81's Avatar
Good, then everything is all ship-shape.
D4u2s0t's Avatar
yep. normally right around 190 or so.
Old 07-12-2008 | 02:20 PM
Blue_Balt's Avatar
Mine runs at 192-194(engine cover off) on the highway. In traffic it's gone as high as 210 and 204 when I took the engine cover off. I've seen it as low as 187.
Old 07-12-2008 | 02:25 PM
that's what i'm, getting give or take.
Old 07-12-2008 | 02:27 PM
MP81's Avatar
Yeah, it peaked at 213, but was more around 204-209
Old 07-12-2008 | 03:08 PM
D4u2s0t's Avatar
mine will go up to almost 220 sitting in a drivethrough or heavy traffic. the cooling system in our car needs airflow. and you dn't get that sitting still. once you start moving it should go down.
Old 07-12-2008 | 03:10 PM
originaladrian's Avatar
the cooling fan in the 2.2 does not come on till exactly 215F. so its normal to be around that, i see high temps everyday in S.FL. a trick is to put ur AC on or get a fan switch
Old 07-12-2008 | 05:10 PM
Jn2's Avatar
Jn2
190 on the highway...220max if i let it sit, than it will come down to 190 when the fan kicks, 190 if the a/c is one
Old 07-12-2008 | 05:59 PM
xxxxsh4d0wxxxx's Avatar
Mine generally runs around 190°F.
brandon04
10-21-2015 08:04 AM
anotherslowlnf
09-29-2015 04:52 PM
z28addiction
09-28-2015 01:03 AM
jmelton327
09-26-2015 11:04 PM
riceburner
09-26-2015 01:57 AM
