cruise control
Youll need a cruise control switch, switch plate and steering wheel harness. You can buy all these.
Youll also need to fabricate a two wire harness from the Airbag coil to the Body Control Module. You can get the necessary(and difficult to use) .64mm connectors from a slave yard by cutting apart a harness, or you can by a radio harness and take it apart, and yuse it to make the circuits you need.
Once you do all this you need to get a hold of a Tech2 to turn on the Cruise in the BCM.
Radio controls are the same process, but no Tech2 is needed.
