Demoding car
Demoding car
Doing a complete demod on the cobalt. Just wondering if any 2.2 guys would be interested in my fully built engine? Gonna post a for sale thread soon so keep your eyes open and farewell to the cobalt and 2.2 game
Sold a bunch already but I still have quite a bit for sale.
New Zzp tubular chromoly control arms (black)
Jbp strut tower brace (black)
Suspension techniques front sway bar (green)
Ottp rack spacers
Progress rear sway bar (black)
Bwoody motor and rear trans mount(new, wrinkle black)
Twm sts with base bushings
9k racing steering wheel with momo hub
Turbo kit (already posted up for sale on here)
Ss/tc upper and lower grill kit (new)
Auto meter mechanical 30psi boost gauge kit
Auto meter oil pressure gauge kit(with fitting for Ecotec)
Vulcan alum coolant tank kit(powder-coated high gloss black) comes with an fittings and stainless braided -6 line
Engine!!!(ill post info and specs soon)
Sold:
Harness bar
Ls4 tb kit
Zzp gauge pod
Bride lomax reclinable seats
Ksport pro coilovers
Aem wideband
Ottp return style fuel system
Catch can set up
Have more just having a brain fart lol
Ottp rack spacers
Sold:
Harness bar
Ls4 tb kit
Zzp gauge pod
Aem wideband
Catch can set up
I'm selling a 2.2 ecotec out of my 2006 Chevy cobalt ls. Engine has roughly 1500 miles on is and was professionally built and assembled by Polarek engines.
2.2 block
Complete rotating assembly balanced
Darton sleeves(machined block and installed to dartons specs) bore and honed engine block
Balance shaft eliminator kit
Eagle h-beam rods
Wiseco 8:9-1 pistons(Teflon coated sides)
Total seal piston rings
Arp rod bolts
Arp main studs
Clevite "H" rod bearings
Clevite main bearings
Cometic head gasket
Crank polished, debur'd and polished crank weights
Ported and polished head, 5 angle race valve job, head resurfaced, cc cylinder head chambers
Comp cams turbo grind cams(balanced)
Cobalt ss/tc (lnf) rockers and lifters
Supertech oversized valves
Supertech 78lb valve springs and ti retainers
Bates spring seats
Bates valve guides
Arp head studs
Bates/gmpp hardened oil pump gears
Timing chain and guides brand new
New front cover and gasket
New water pump
New front and rear main seals
Lsj valve cover cut, welded, modified, powder coated to fit 2.2
New valve cover gasket set
Modified lsj coil cover to work with 2.2 coil pack(modified)
Fidanza flywheel
Arp flywheel bolts
Lnf timing chain tensioner
Have all the paperwork from the shop that assembled the engine as well. I may be forgetting some things but you all get the point! I'd like $5,000 o.b.o
Text or call me for more info or pics, 2195082361 names Ryan
2.2 block
Eagle h-beam rods
Arp rod bolts
Arp main studs
Cometic head gasket
Bates spring seats
Bates valve guides
Arp head studs
New water pump
Fidanza flywheel
Arp flywheel bolts
Ati superdampner crank pulley
Billet alum alt pulley
Racequip 5pt harness (Simpson sold)
9k racing shift knob
Hurst pistol grip shift knob
And much much more I can't even think of right now
How much are you looking to get out of your turbo kit? I have been looking around, even tried to piece it together and haven't had much luck. Really don't wanna buy one off of ebay. I found one brand new for $1300 but he wanted to get rid of it. So I really don't know how much I am looking at for a used one that isn't screwed. If you could get back to me soon, that would be great. I can't go over $1,000. Does it have anything special? Like a bigger turbo or so. I know it's a low budget but I really can't go over that at the moment. If you can't go down that low, it would be nice if you could let me know how much you would sell it for.
Bump!!!!! I have pics of 90% of parts I have fs. The other 10% is still at Steve's house but ill have it all cleaned up and at my house by next week and pics pics pics! Lets get this stuff sold and put to use like I never did
