Do the gm stage2 injectors fit or not?
did you ever get this issue resolved? i'm having the EXACT same issues with the GM 42s...
I had the issue resolved for a short period of time (replaced o-rings on "caps" that go on end of injectors) but had to pull the injectors and haven't gotten it to work right since. Seems to me like the L61 needs a longer injector (like the 60s) for them to install correctly. Injector installs shouldn't cause this many problems IMO.
btw, have the part # for that cavalier injector harness?
Here's the harness p/n
NP man, lol... Yea me too, lol... from the first time i put those injectors on i thought there would be problems, and there were. I don't know if i want #60 either, they seem to cause alot of missfire issues. but they will probally be the replacments for my 42's.
Oh btw, is your misfire issue still there at idle?
My car seems to idle at the proper rpm but will randomly misfire at idle. My AFRs will also dip into the low 10s when I first get into boost < 5 psi.
Never had a missfire issue, just idled up and down in the beginning and would throw p0171 fuel trim lean codes. but all that was fixed with the tune. Now the car idles at approx 1000 rpms, no surge. About 11.5 afr in boost and runs really well. No more codes either...
Delta coupe
09-30-2015 08:11 AM
