Which Downpipe?
Which Downpipe?
What downpipe is best for the 2.2?
Right now my setup is a DC Sports Header SS/SC DP and a DC Sports Cat Back Exhuast
Which is better Catless or a High Flow Cat?
btw i do not want it to sound raspy
ok thanks bro and i do not know if my aeroforce interceptor gauge is right or not but when i kick it reads almost 150hp do you think that that is correct for my mods
In order to get to 200whp you would have to do some major modifications.
Something like this:
Patriot Performance Stage 2 Head
Upgraded valvetrain for high revs (Probably 8K)
Higher compression pistons
Stage 2 or 3 cams
Tuning capabilities
Or, you could just buy a 75 shot of nitrous and save yourself the hassle.
Stage 2 or 3 cams
Tuning capabilities
The convention seems to be that you can run a 50 shot all day long, and use a 75 shot pretty frequently as well. It took a much bigger shot to break the rods in the 2.2 when GM did their testing. (IIRC ~150)
Here is a good place to start:
https://www.cobaltss.net/forums/nitrous-oxide-51/what-you-need-run-nitrous-look-here-95114/
ok thanks bro and i checked out patriot perfromance they have some good stuff for the 2.2 thx for all of the info
hope to break the 200 hp mark soon in a ls
Just be warned that unless you are going to seriously increase your redline, or go f/i, the Patriot heads won't be maximized. I believe Ion ninja has a stage 2 head, and he mentioned that his powerband had shifted to the higher RPMs quite drastically. Low end performance is greatly reduced if you stay n/a. If you don't want to dig too deep, go with the nitrous.
