Downstream O2 Sensor
Old 02-26-2015 | 09:56 AM
SmithT91's Avatar
Hey guys I used the search function and I couldnt find it, I scoured google and couldnt find it either... but my car right now sounds like its got a boxer engine, low power, sluggish etc... I thought it could have been a plug fixed that, still bad, cleaned injectors, still not, replaced coils, still... my stupid A$# didnt check the codes first turns out its bank 1 pos 2 downstream o2 sensor, so I got up under my car and noticed where the sensor is at the wires are frayed.. so now im planning on replacing it sadly most of my tools,jacks,etc. Are back in NM and im up in Texas with my GF so I got the tools to remove it and a crappy manual jack.. my question is because I really dont want to be under the car for long is where exactly is the connecter located at so I can just get under there and do a quick swap.. any help is greatly appreciated.. thanks guys!
Old 02-26-2015 | 10:49 AM
sandman's Avatar
Connector can be reached by hand through the engine bay. the sensor itself will be on the flat part of the downpipe before the catback. It is probably rusted in too lol so you are gonna have to yank on it
Old 02-26-2015 | 10:58 AM
LTBALTBMX's Avatar
Don't wrench under your car with just a jack, no matter how quick you will be.
Old 02-26-2015 | 11:10 AM
SmithT91's Avatar
Ok so you are talking about the sensor that furthest away from the engine bay correct? Closest to the muffler? I know where the sensor itself is and its already loosened, I am just trying to figure out exactly where the connector is so I can just unplug it and do a quick swap. Again thanks for your help.. if anyone has pics or could provide pics to where the connector is I would be so greatful!
Old 02-26-2015 | 11:12 AM
SmithT91's Avatar
@ BMX yeah I decided to just buy jack stands too they are only 30$ for a pair and I already have chalks.. after thinking about it id rather be safe then sorry.
Old 02-26-2015 | 11:13 AM
sandman's Avatar
the connector is gonna be in the bay on the drivers side down a little ways somewhat close to the firewall. It's gonna be a bit of a reach but you can grab it. I don't have pics currently
Old 02-26-2015 | 11:22 AM
SmithT91's Avatar
@ sandman, does that mean if the whole front is jacked up that you could just access it from underneath? Or would you recommend just going from the bay?
Old 02-26-2015 | 12:17 PM
tuned08ss's Avatar
Yes its on your downpipe. Part of the exhaust
exninja's Avatar
On the LNF it's pretty easy to reach from underneath, but it's difficult to see. The connector has a little plastic thing that locks it together and if you can't see it it's kinda hard to figure out how to pull it apart. If you can see it, then it's pretty simple to figure out.
Old 02-26-2015 | 02:47 PM
sandman's Avatar
If you have skinny long ass mother ******* arms like I do I'd recommend going through the bay lol
Old 03-01-2015 | 03:23 PM
nhanson's Avatar
2nd O2 is not going to affect the car like that.
Old 03-02-2015 | 04:55 AM
Jesse's Avatar
This. There's no way. OP where in TX are you right now?
Old 03-02-2015 | 10:50 AM
exninja's Avatar
While that may be true, if he's got a code for the sensor and the wires are frayed then there's no reason not to fix it.
Old 03-03-2015 | 11:41 PM
05g5's Avatar
It's the cat... Clogged forsure
The frayed wires is a coincidence IMO. Still fix it
But that sensor has no control over the motor and how it runs. All if does is make sure the cat is operating within spec. If the cat is not operating properly, you get the cel
Old 03-10-2015 | 11:21 AM
SmithT91's Avatar
Im in bandera,tx north of san antonio, and I dont have a cat its just a down pipe.. and before I noticed the wires it was random, but after I got under the can and fiddled with it and one of the frayed wires snapped..its constant(lower power) coincidence?
Old 03-10-2015 | 11:24 AM
SmithT91's Avatar
Down pipe may not be the right word.. but an off road "cat". Mind you I have mid length zzp headers and trifecta tune as well.. on top of injin cai are you sure the o2 isnt the problem? I was under the assumption that sense my cat is not really a cat in the sense that theres no filter that it really wont get clogged.. sorry for the ignorance :/..oh and 2.25" head back exhaust. Just adding the upgrades as I remember them
Old 03-10-2015 | 08:26 PM
SmithT91's Avatar
And doesnt the sensor help regulate afr?
Old 03-13-2015 | 02:00 PM
SmithT91's Avatar
Bump. Please I really need help here .
Old 03-13-2015 | 02:46 PM
exninja's Avatar
No, the downstream sensor only monitors cat performance. The upstream sensor is used for fuel trims.
Old 03-18-2015 | 09:55 PM
SmithT91's Avatar
Sooo I scanned it and it threw these codes
p0141
p0138
p0134
p0054
p0036
P0301
p0833
p1133
p2a00
does that help you guys at all? I'm going to assume it's bank1 pos1 sensor?
Old 03-19-2015 | 02:53 PM
SmithT91's Avatar
most of the codes are for bank2,pos1. One for the clutch petal(someone replacing my clutch took the whole clutch petal out instead of just the linkage) when looking at the codes the first time I totally didn't notice the 2(3?) Codes for the upstream...
Old 03-19-2015 | 05:38 PM
SmithT91's Avatar
Sooo any input would be greatly appreciated, I've alreadywasted so much money trying to get the balt up and running
Old 03-20-2015 | 02:45 PM
SmithT91's Avatar
DarrenGC
12-24-2021 02:55 PM
Sl0wbaltSS
11-22-2018 12:11 AM
Tupp
2.2L LAP Performance Tech
01-02-2016 01:04 PM
jmelton327
09-26-2015 11:04 PM
Knightwolf
09-12-2015 12:02 PM
