dowpipe question
dowpipe question
hey guys i got a question...my cars got the two cat dowpipe on my car...does anyone know if the ss downpipe will swap just fine and im sure im going to need a tune since the cat systems must be different? i just need some help with this guys...thanks in advance
ps if im doing a tune im doing a 2.4 throttle body and an ss header and downpipe.
yee thats it, if u do this make sure the top of the downpipe matchs up like pipe size and gasket and all match up. i blew a gasket on my aftermarket downpipe and the stock gasket was too big haha, but i got a better gasket problem solved haha
u should be able to bolt up no problem just check the specs and stuff
two cats? damn haha it should be fine it wont be as restrictive cuz the cat helps keep noise down haha thats why catless cars are freaking beast.
i have a 2.0l supercharged cobalt and im not familiar with the 2.2l motor but it should be similar as u will just be running a single cat and have better air flow
heres a pic of my vibrant downpipe and the lsj (stock) downpipe
You shouldnt need a tune. Just find a dp from an ss that is the same year as yours and there should be no issues. Everything should just bolt up just fine.
I just noticed your an 06 I would try and get a ss mani also.
Last edited by 2007victoryred; 08-17-2009 at 01:48 PM. Reason: Automerged Doublepost
This is on the 2.4L Cobalt...the 2.2 has the same issue:
https://www.cobaltss.net/forums/show...&highlight=LSJ
the downpipe im gettin is from an ion redline i assumed that essentially an ss downpipe...and i already checked i have one o2 on my mani and the other on my dp
