Dual Exhaust
Old 01-02-2011, 03:51 PM
C_A_D88's Avatar
Originally Posted by b00sted06ss
heres an example of why not to do a dual exhaust on a base model bumper
Cars for Sale: 2005 Chevrolet Cobalt LS in Kansas City, MO 64138: Coupe Details - 289106079 - AutoTrader.com
do NOT do it this way lol
Old 01-02-2011, 04:03 PM
BlackLsCoupe's Avatar
had it on mine cut muffler off had a guy duel pipe it from there was set up and back so it didnt look ugly. got better gas milage
Old 01-02-2011, 04:08 PM
C_A_D88's Avatar
only thing is you gotta cut your bumper to have the exhaust cutout to make it look factory
Old 01-02-2011, 08:23 PM
jdgpuller's Avatar
did you see the way mine was done on my cobalt
Old 01-02-2011, 09:14 PM
C_A_D88's Avatar
yea looks decent
Old 01-02-2011, 11:07 PM
strykr's Avatar
As long as you do it right, itll look good and WONT loose back pressure.. look at the 01+ 2.0L neon's they actually look nice and GAIN power going from stock exhaust to the dual exhaust, and the 2.0L are NA (if someone is curious (granted they are sometimes modded to turbo setup))
But like I said.. if you do it right it can look nice and wont loose power. If I was to do it, id get a SS rear bumper that has dual cutout and have the exhaust run to a muffler and on the output side have it dueled..
This is what is on the Neon R/T's, I actually miss having mine it sounded very nice!
EDIT: C A D88, have you been to the Highway 7 meets in Vaughan ON? I think ive seen your car before..
Old 01-02-2011, 11:20 PM
ecot3c inside's Avatar
you do NOT lose power! there is only a cat-back non-true dual exhaust here folks!! It should be fine. do w.e you want. just not that autotrader one ^ **** looked like it was going cross country skiing
Old 01-02-2011, 11:23 PM
N1ckateen's Avatar
Originally Posted by Gestapo007
on a 2.2? nah. on an SS, better. IMO. you dont have the bumper for it to look right. If you got a new rear bumper that had duals or something itll be better
The master has spoken
Old 01-02-2011, 11:30 PM
Acey's Avatar
Originally Posted by BlackLsCoupe
it didnt look ugly
...says you. Of course, the high rise doesn't help.
Originally Posted by Blue_Balt
Plenty of 4 cyl cars come with dual exhaust from the factory (Altima, Tiburon etc).
Aye... and more relevant would be this car, given it has an L61
Old 01-03-2011, 09:16 AM
jdgpuller's Avatar
both tips are hooked up and sounds great
Old 01-03-2011, 09:48 AM
  #36
Dart_SI's Avatar
im putting dual exhaust on my ss/tc this march. already have all the parts and everything. SLP dual outlet. hope it sounds good. all i gotta do is get the flange changed and take my rear lip to a body shop so they can cut out the other side perfectly. i could do it myslef but i want it to look good. lol.
Old 01-03-2011, 10:07 AM
  #37
jonxxxedge1's Avatar
Originally Posted by jdgpuller
both exhaust tips are hooked up so when its cold outside you can see stuff come out both tips
it dosent come like that stock then. if you look under the car, the right tip is just bolted there, and the stock muffler flows into the left tip
Old 01-03-2011, 10:36 AM
  #38
C_A_D88's Avatar
no i havednt been to the meets yet but you may have seen me around tho
Old 01-03-2011, 11:36 AM
  #39
jdgpuller's Avatar
not any more i upgraded the exhaust to 2.5 inch and a thrush welded series muffler and hooked both exhaust tips up and your right its not factory
Old 01-03-2011, 01:40 PM
  #40
newt's Avatar
Back Pressure is a old myth. The perfect exhaust system has LITTLE to ZERO back pressure.
People are confusing back pressure with exhaust velocity.
If you lose exhaust velocity you will lose power....end of story....nothing to do with back pressure.
That being said, I have a L61 in my sunfire, its open header (dumps to atmosphere where the cat used it be) and it made (dyno proven, with sheets to prove it) 9whp and 15wtq over my 2 1/4 exhaust with a straight through muffler.
And no, I didn't lose any "low end power" either. It makes more HP/TQ from 2000rpm to redline with the open header.
So please don't try and tell me, or other people on this site, that simply running a dual muffler on your car will lose power because you will lose back pressure.
A closed mouth collects no feet....
....Something some of you should think about before posting sometimes.
Sorry, this is one topic that bugs the hell out of me!!
Old 01-03-2011, 02:12 PM
  #41
cfcobalt's Avatar
i have dual exhast on my LT
(before i went wingless)
Old 01-03-2011, 05:57 PM
  #42
whats wrong with the high rise? and i got lots of people at the car shows that loved the duel exhaust and it sounded good to.
Old 01-03-2011, 08:08 PM
  #43
finally someone who has actual evidence to back up. I do believe you but i wouldnt mind seeing the dyno sheets, and what changes you've done between them (trying to decide what direction to go with my l61)
Old 01-03-2011, 08:38 PM
  #44
newt's Avatar
Dyno runs where done back to back. Full exhaust first, open header second (I have an electric cut-out).
I'll post the sheet tomorrow
Old 01-03-2011, 08:58 PM
  #45
Nice, thanks
Old 01-04-2011, 02:19 PM
  #46
newt's Avatar
As promised.
Old 01-04-2011, 03:31 PM
  #47
Thanks, finally can end the myths and rumors
Old 01-04-2011, 03:42 PM
  #48
padlock's Avatar
As promised.
this is worth quoting so everyone sees it again!
Old 01-04-2011, 03:49 PM
  #49
newt's Avatar
haha I had this same argument with people over at J-Body.org, I used to run at the track with the exhaust open and got better times. No one would believe me that the open header would make more power, so on the next dyno day I decided to try both so I could prove it.
The people that did believe me argued that I would lose to much low end TQ to make it worth while. Aside from the fact when you drag race you never really use any low end TQ since the RPM's don't drop enough between shifts. As you can see I didn't lose ANY low end TQ, I actually gained some.
Keep in mind tho, that if you do want to run open header there is a bit of a science behind it. Google "collector extensions" you need a distance of pipe beyond the collector in order to gain power.
The biggest gain is mid-range TQ and as you can see by the graph that is where it gained the most power.
Just trying to help disspell some myths....nothing erks me more than misinformation....lol
Old 01-04-2011, 03:51 PM
  #50
08ssedan's Avatar
Originally Posted by asherby85
Pros - None
Cons - Eliminates back pressure so you actually LOSE horsepower - You'll like like a dummy for a putting a dual exhaust on a 4cyl car.
I can think of plenty of 4 cylinder cars that come with a dual exhaust from the factory. Lol
01-12-2016 12:01 AM
hacadacalopolis
10-28-2015 06:09 PM
nathan112i
09-30-2015 07:12 PM
z28addiction
09-28-2015 12:03 AM
09-27-2015 08:53 PM
Quick Reply: Dual Exhaust
