ebay intake for less....
#231
might as well. The only complaint i have about mine is that at WOT it vibrates on the opening a little bit. I have some left over garage groumet that i'm gunna use to fix it when it gets warmer out.
#235
this is the ebay CAI on the 2.2s
This is what the ebay CAI looks like on my 2.2L....should be close to yours..remember to file down the MAF slot to fit the maf easier and then also inspect the inside for any loose metal bits from the weld that could get sucked into the motor......they're great CAI, but you get the welds you pay for...
By the way DO TAKE THE TIME to attach it to the side of the fender while your putting on the air filter below.....otherwise you'll vibrate a hole right through the intake in 10,000 miles
#236
wut do u mean by file the maf slot, and also attaching it to the fender? i havent heard anything about that...
#237
MAF slot can be a little tight some file it a little to make the MAF fit better. And attaching it to the fender he is saying install it right. (bolt it down, not letting it just hang in place)
#242
I don't have a camera right now but, use the rubber spacer thing with a bolt sticking out of each end, bolt one end to the fork thing on the intake and the other to the inner finder.
#243
#244
Man Wat Luck I Have I Tryed To Orderd One And They
Told Me They Sold Out For 3weeks Price Is Now $49.99 But
La Puente Is Like 20 Mins From Where I Live I Asked If Ican
Purchase It In Person N They Said Yes Ican Pick It Up The
Same Day So Hopefully I Will Have Mine In 3wks Or Less
#247
#248
i would suggest gettin a new inner fender first cuz the filter will be in the wide open if you dont.. as far as all that filing goes i didnt have to do anythin like that to mine and my maf sensor dont stick out that far either..
