ebay intake for less....
Old 06-30-2008, 01:19 AM
  #476
Jn2
Jn2's Avatar
i have had mine for a while now, no CEL and i have a KnN filter on mine, all is well
Old 06-30-2008, 01:26 AM
  #477
rmpro1's Avatar
hmm this sucks it sounds so good i dont want to have to take it off to pass emissions..
Old 07-02-2008, 12:32 AM
  #478
rmpro1's Avatar
alright the CEL went off today haha and it has not come back on, happens to go off right when im on my way to get it read lol. hopefully doesnt come back on..
Old 07-02-2008, 09:58 PM
  #479
kingarthur's Avatar
Just got mine in today, got a quick question for those of you who already installed it.
Where do you bolt down the bigger tube?
I see it has a bolt holder welded on it but can't figure where to attach it.
Thanks
Old 07-02-2008, 11:19 PM
  #480
dasudevil's Avatar
i had to bend mine to fit it in the hole on the side.
Works great. I used the small rubber tube (in the middle) that i replaced with a longer one as a washer. both sides, new bolt and nut, tighten. Does not move at all.
Old 07-02-2008, 11:39 PM
  #481
TurboTechRacing's Avatar
We are confused on why members would get an Ebay intake.... There have been post on just using "tubing" and members actually LOOSING 6-8 HP as the intake 1. was not tuned 2. does not have the correct air dynamics. If you are doing it for sounds and dont care about power, I guess that would be fine.... But an intake is not an intake. There is a reason why K&N, AEM, and Injen intakes are more... They test them to perform.... Not loose power to the engine... Do a search you will see what we are talking about.
Old 07-02-2008, 11:53 PM
  #482
FutureEcotecOwner's Avatar
LOL!!! I totally understand where you're coming from. When I bought my intake and SCT tuner for my 05 Mustang GT, I didnt go with a cheap $150-200 intake and tune, I got a C&L CAI intake and an SCT tuner, ran me almost $800 total, but you know what, it has been proven over and over again that it gives 20-25rwhp to your 05+ Mustang GT. I dont have a Cobalt or Cavalier yet, but when I get one its getting either an AEM or Injen CAI.
Old 07-02-2008, 11:55 PM
  #483
elecblue06's Avatar
where as i respect you as a vendor and think you guys are awesome... thats not cool and i haven't seen a case where this is true
this isn't the first time you've done this in this thread man and sorry but alot of times.. intakes cost that much because of the name
Old 07-02-2008, 11:59 PM
  #484
We will find the post and post a link....
Old 07-03-2008, 05:30 PM
  #485
rmpro1's Avatar
This is what mine looks like put the K&N Filter on it
it has a really nice tone
okay the picture didnt show up lol
Old 07-03-2008, 05:39 PM
  #486
umrdyldo's Avatar
Turbo Tech Please post a picture of an AEM intake on here. It will be pretty obvious if the design is close to the Ebay Intake.
Losing 5-6 HP is not possible. Its metal pipe. The air restriction is much less than the stock BS. Hell the stock intake has 2 baffles essentially.
Old 07-03-2008, 06:10 PM
  #487
Jn2
Jn2's Avatar
the AEM and the ebay one are identicle down to the location, angle, and size of piping, evertyhing is the same minus the AEm decal
Old 07-06-2008, 04:36 PM
  #488
guitarguy0622's Avatar
3 things...
1. does anyone know when the intake will be back in stock?
2. where can i find a good filter that doesn't cost a whole lot?
3. i'm planning on buying a cover for the filter called a hydro-shield by injen for $39.95, b/c its always raining down here and i don't wanna drench my engine. anyone have this and whats your opinion on it?
Old 07-06-2008, 05:02 PM
  #489
outtamymind's Avatar
guitar guy for info on stock send the company an email. now the filter you can buy at any parts store i got my from part source. and the hydro sheild is a good investment if you live in a high rain environment, just means you can drive a little better without having to worry about soaking your motor with water.
Old 07-07-2008, 12:27 AM
  #490
Jn2
Jn2's Avatar
just get a bypass valve and use it in place of the coupler, works fine, even better than the shield
Old 07-07-2008, 01:25 AM
  #491
ok, thank you. i actually e-mailed the company last week and have yet to receive a reply. What size filter should i get and do the difference in brands really make a difference?
how much would a bypass valve run me? the hydro-shield costs $40.
Old 07-07-2008, 07:56 AM
  #492
PSPCobalt's Avatar
So Name Brands Dont Have Nothing To Do With The Cold Air? This Is a Good Find Since Im Low In Cash Right Now.
Old 07-07-2008, 06:35 PM
  #493
it should be a 3" filter. but what i did is took the tube that the filter goes on and took that with me into the parts store and made sure the one i got would fit. and i just got a lesser known brand one and it works fine.
Old 07-07-2008, 07:31 PM
  #494
ok thank you very much. that was helpful. hopefully they will get this intake in stock very soon.
Old 07-08-2008, 01:15 AM
  #495
Jn2
Jn2's Avatar
the AEM bypass will run you about 45, but if you get the no name one, it will be cheaper, just go on ebay and search for bypass valve...find the 3" one and ur set, what it does it suck air thru the filter, but when there is a pressure drop aka aubmerged filter it will suck air thru the bypass filter...works fine, and just use it in place of the coupler joining the 2 pipes, although one side will be tighter than the other as the pipe is smaller, butt hats no problem...and i recomend the AEM
Old 07-19-2008, 09:48 AM
  #496
I found another intake on ebay. This one seams like a good deal but when i looked at the picture the placement for the MAF sensor was in a different location then the JDM intake. does this really matter?
new ebay intake:
jdm intake:
Old 07-19-2008, 10:54 AM
  #497
Whitty's Avatar
i was looking at the same one, if you look closely it looks like the bottom "maf" position is blocked off ? and there appears to be another one at the top in the same spot as the JDM i'm almost positive they are the same intake.
Question tho. If i am to get this ebay intake posted above and it is the same as the JDM people have mentioned having to file the MAF sensor adapter because it is too small, is this a lot of work ? like how far off is it? and will this throw a CEL ? Thanks again i know its probably been covered but i'm sorry i dont have the time to re-read 28 pages lol
Thanks!
Old 07-19-2008, 02:29 PM
  #498
guitar guy if i'm not mistaken that ebay intake that you put a pic up of is for the 2.0 and the jdm intake has worked flawlessly on my 2.4. yes you will propably have to file the maf holder a little but its not hard work just need a good metal file and your good to go. and i've had mine on for about a month now and no cel's and its been raining everyday, just got to remember to not hammer it when it rains or you'll screw your motor up from sucking in water.
Old 07-19-2008, 02:47 PM
  #499
the new ebay intake says it fits the 2.2L so now i'm confused, which one is it for? and if it is for the 2.2L is it me or it the MAF sensor in the wrong spot?
Old 07-19-2008, 03:15 PM
  #500
Whitty's Avatar
it certainly looks like it is in the wrong spot but i have no way of knowing 100% it says in the description on ebay that the item is exactly as pictured... so i am kinda confused too lol
Quick Reply: ebay intake for less....
