eco re-start
put a small ammount of oil down the spark plug hole. and do above^^^^^^ mine sat for over a year and fired rite up
noticed your from mn saweet!
didnt you have the blue cavi 2.2 with a 2.9 pulley?
I'm old school
When you put the engine back in the car, run the engine through several rotations on the starter first without the fuel or ignition hooked up yet. This will allow the fresh oil to pump through the block and get some pressure built up. It will also show you any problems the engine might have even without it running under its own power.
my dad said that i should pull the valve cover off when i change the oil and pour half a quart over each cam to make sure they are well lubed as well. then un hook the injectors and the ignition and turn the motor a few times for the oil pressure. ( all of that after i get some oil on the cyl walls. )
yay or nay?
yay or nay?
I'm old school
yay or nay?
yay or nay?
i will be firing the car this weekend and driving it for the first time a long time... so wish me luck. i will post updates
