Ecotech 2.2L plugs
the best ones to use are the Bosch Platinum +4 or the new Iridium/Platinum +4 by bosch. They are better than others because they have 4 electrodes rather than just one.
Hold on now...why do people just call things pieces of ****.......
Here's how it works, if your an 05 or an 06 with a coil and distributor separate, then you run Delco's or NGKs or stuff like that and both of those are good brands I haven't heard a ton of complaints about either one of them.
Bosch +4's are good for the 07s with Coil On Plug setups....I have had the same set in my car and they haven't failed me yet (put them in at 5,000 and havent had a problem in the last 34,000) , however they seemed to have fried severla 05/06 coils when they're applied to those cars...so just be fair and this is an honest assessment based on all the threads that have come up in the last year or so....
Peace!
Peace!
I have had them in for almost 15000 miles and it runs perfect. I'm running 93 octane anyhow so it helps to ignite it better. Plus if i was getting misfires the CEL would be goin off constantly so.
wrong those plug are GARBAGE!!!!!i steer everyone away from those when they ask for them at my work.i tried them on two different gms and both ran like ****.changed them out with ngk or delco and ran perfect.....ill be doing ngk in my balt when needed seeing my buddy is making 2400 hp and runs only ngk plugs in a 430 ci chevy big block!
Bosch Plat ruined my ignition pack too, cost me over $400 to replace.
Why are you running 93 octane on a stock compression, naturally aspirated car?
You do realize that it is HARDER for your engine to burn 93 octane as opposed to 87, correct?
Peace!
Peace!
That was all in your head. Any new plug will make the car feel better after you replace your old stock plugs.
helps it ignite better, eh? you should not be telling people that they don't know about cars.
i believe he was refering to the fuel because 93 octane would actually take more to ignite. and just because it has 4 electrodes doesnt mean its going to ark to all 4.. not going to happen.
