Entire Exhaust Question
more than likely most dealers will not know the difference in the 2.2 and 2.4 mani's they look alot alike except for the runners are a lil bit bigger. so unless they happen to really know somethin bout the balts then they will not ever know the diff in it. as far as voidin the warranty they cant untill they can prove that a mod you did actually caused a problem you bring the car in for. all they can do if the happen to know its not the mani that came on it is flag your warranty so they know you have somethin different on the car than what was suppose to be there. no for your exhaust question. 2.5 is the biggest you'll want to run on your car unless you go f/i cuz the motor wont ever put out enough power n/a to support usin 3in or larger exhaust.
Ok perfect man thanks alot youve helped me out alot in deciding what to do,Im def going to do this a few parts at a time and store them until its complete.Im just not sure what to do about the CEL's that are going to occur.
its an 07 thou and should have sai (or AIR as maven said it is really called lol) on it. just look comin from the factory intake and the factory exhaust mani. it will be black plastic pipin. all you will need to do is get a tune to have it turned off.
btw florida emissions requirements are almost as bad as CARB aren't they?
