ETA For 2.2 Tuning???
Old 08-24-2007, 04:32 PM
  #126
Sw4y1313's Avatar
Originally Posted by bc3tech
if i could, duane, i recommend tuning the 24's on 8psi... they'll more than handle it. just so you don't (accidentally or otherwise) wash your cylinders or do a rich-detonation like i did. then that way you've at least got THAT tune to use on the 32's initially and tweak. instead of going 0-60 (expression, not the injectors ) straight off.
.... or like what they've been saying for the past 2 years....
Thats true brandon, good idea. If you want, Ill send you my tune as soon as i have one made.
I will be doing all the tuning research next week so its fresh in my mind when i plug this bad boy in and start tuning. It shouldnt be to hard because it will be MAP vs RPM. Kevin, you flyin down buddy? hehe
Sw4y1313 is offline
Old 08-24-2007, 04:35 PM
  #127
Speed Mafia's Avatar
good advice. the RL guys have been trying to do a return style fuel system for a while now due to their cyl 4 lean issue... nobody's come up w/ a nice solution as of yet. alphajaguar was heading it up last i knew, but it kinda died off.
running a return line is very simple...as for the lean 4 i would probably say a split the fuel rail in half and then use a fuel block so each injector gets the same amount of fuel...aeromotive makes nice blocks!
Speed Mafia is offline
Old 08-24-2007, 04:36 PM
  #128
Sw4y1313's Avatar
Originally Posted by elvisc
i would recommend making it a return style fuel setup because 60lb injectors may not be able to pulse so fast to shoot so little fuel at the high fuel pressure we have stock.
So this way when you have vacuum the injectors won't have as much fuel pressure so the fuel injectors are not so stressed out trying to pulse so quickly.
Then at higher KPA values the fuel pressure can increase and then yay more fuel.
its just pulls the stress off the injectors and the injector drivers.
just my .02
doublepost: also don't make your goals off PSI levels, that's just a pissing contest.
Do it off HP goals that way you know what injectors to get for the desired HP goals...etc
Yeah good idea, ill have to look at that issue when it comes up. Im sure we can figure something out.
But yeah im not basing my stuff on PSI, im just saying 8psi right now because i know what its producing with the 5th injector setup and just want to get it running with the AEM FIC to make sure it works properly. But yes all my goals are hp based. I already know exactly which injectors i will be using for each setup. Im just using PSI here for easy reference to make it a little more simple.
The largest injectors i will be going with are 60's running at a 90% IDC will get me around the 380-400hp mark on our fuel pressure. My thoughts about the FIC are that i dont think it will work well with anything higher then 60lb'ers. The reason being is it changes the pulse width when switching out primary injectors. I think if someone is going to go over 60's they should switch to 4 secondary injectors. That will allow for stock injectors to run the car under vacuum and the secondary injectors to run the car purely under boost, giving you precise fuel delivery to each cylinder. When setting up secondary injectors with the FIC, the secondary injectors will fire at the same time as the primaries. No fuel puddling to worry about, specially when the injectors are inside the runners.
Honestly the hardest part of this is going to be manipulating the o2 signal to keep the cars trim in line. It cant see over under 14.7 anywhere under 85% throttle. Thats not gonna be easy. I have a feeling im going to be throwing it into limp mode a lot...
Sw4y1313 is offline
Old 08-24-2007, 04:39 PM
  #129
But yeah im not basing my stuff on PSI, im just saying 8psi right now because i know what its producing with the 5th injector setup and just want to get it running with the AEM FIC to make sure it works properly. But yes all my goals are hp wise according to injector size. Im just using PSI here for easy reference to make it a little more simple.
i see in your sig you are basing things off of HP numbers nice!
Old 08-25-2007, 03:10 AM
  #130
CobaltFan06's Avatar
Just got a reply from them =P
Hi,
He either spoke to a non tech employee that didn’t know or misunderstood, we don’t have tuning support for this car yet.
Hopefully soon
Allen
Nah we had Allen on speakerphone, he said yes to every question we asked. However, he assumed that we were already running a piggyback system... which is where the misunderstanding happened. So yes, your right, they can't tune a 2.2 without any help from an aftermarket system.
CobaltFan06 is offline
Old 08-25-2007, 12:13 PM
  #131
elvisc's Avatar
with the return style fuel rail you'll be able to put bigger injectors than 60lb but with a lower fuel pressure so the (example 72lb) injectors will act like 55's or so.
Adjustable fuel pressure regulator ftw
elvisc is offline
Old 08-25-2007, 12:15 PM
  #132
LScoupeTUNER's Avatar
<<< lost
LScoupeTUNER is offline
Old 08-25-2007, 12:24 PM
  #133
NJHK's Avatar
Originally Posted by LTcoupeTUNER
<<< lost
Which part confussed you?
NJHK is offline
Old 08-25-2007, 12:35 PM
  #134
Novajoe's Avatar
he heard people were actually trying to make power with the 2.2. ftw!?!?!?!?
Novajoe is offline
Old 08-25-2007, 12:52 PM
  #135
NJHK's Avatar
Wow...
You do realize there are 11 and 12 second street cars with 2.2s and tons more in the 13s, right?
Do you know anything about the ECOTECs?
NJHK is offline
Old 08-25-2007, 12:53 PM
  #136
elvisc's Avatar
if you're talking about me, uh then no.
i've been making power with the 2.2 for a long time
if you don't get the whole fuel pressure thing then do some research.
elvisc is offline
Old 08-25-2007, 12:54 PM
  #137
Novajoe's Avatar
Wow...
I know nothing about ecotecs. But I love sarcasm
Novajoe is offline
Old 08-25-2007, 12:55 PM
  #138
NJHK's Avatar
Elvis, just ignore him. He's clearly ignorant.
Sorry but saw no sarcasm in it. Though this is the internet.
NJHK is offline
Old 08-25-2007, 12:57 PM
  #139
Novajoe's Avatar
I've built car's you only wish you could own
Novajoe is offline
Old 08-25-2007, 12:58 PM
  #140
NJHK's Avatar
So that's the reason I should gargle your *****?
NJHK is offline
Old 08-25-2007, 12:59 PM
  #141
Novajoe's Avatar
no it's the reason you should watch who you call ignorant.
Novajoe is offline
Old 08-25-2007, 01:00 PM
  #142
NJHK's Avatar
You're ignorant when it comes to ECOTECs...you showed it by your comment.
NJHK is offline
Old 08-25-2007, 01:01 PM
  #143
Novajoe's Avatar
lol why because I made a joke? You're ignorant when it comes to life. And you've shown that by your comments
Novajoe is offline
Old 08-25-2007, 01:11 PM
  #144
NJHK's Avatar
lol life?
So you know my life because of a internet forum, right?
Funny cause I have no idea who you are.
NJHK is offline
Old 08-25-2007, 01:14 PM
  #145
Novajoe's Avatar
lol life?
well I can tell that you obviously take this internet forum stuff way too seriously. If your cobalt had nuts you would be hugging them ferociously right now.
Novajoe is offline
Old 08-25-2007, 01:16 PM
  #146
NJHK's Avatar
and if you knew how to read you would have seen that I DON'T OWN A COBALT.
But nice try.
(PS: look at my signature big boy)
NJHK is offline
Old 08-25-2007, 01:20 PM
  #147
Novajoe's Avatar
But nice try.
even worse... you don't even own a cobalt and you're nut-hugging
Novajoe is offline
Old 08-25-2007, 01:38 PM
  #148
NJHK's Avatar
ROFL
Whos nuts did I hug? All I did was state facts.
Never answered my question, how am I ignorant at life?
http://www.morganquitno.com/edrank.htm
Hmm Alabama is #45
Nevermind, I don't blame you for being stupid.
NJHK is offline
Old 08-25-2007, 01:41 PM
  #149
NJHK's Avatar
lol probably
NJHK is offline
Old 08-25-2007, 11:55 PM
  #150
Novajoe's Avatar
lol probably
actually I was educated in arizona. Don't make assumption's. You have no idea what kind of education I have.
Furthermore I can tell you're just going to keep getting more and more immature as this goes so as of now I'm washing my hands of it. It's not my problem if you can't take a simple joke. And even if you didn't know it was a joke, you reacted to it in an extremely immature way by trying to call me out on things about me you have no idea about. By all means though. keep going. I'm having fun watching you make an ass out of yourself.
Novajoe is offline
Quick Reply: ETA For 2.2 Tuning???
