Excedy stgII clutch install
Old 04-19-2010, 02:26 AM
06_ion2's Avatar
Mine engages about 1 1/2 inch off the floor. You can get a adjustable clutch rod.
Try to bleed it from the resivor this time?
Old 04-19-2010, 02:33 AM
madmark's Avatar
you have a leak lol, find where its letting air in. or if you want your left leg to stay strong just pump it
Old 04-19-2010, 09:25 AM
rockstarbass1's Avatar
Ugh I have this to do this weekend or next and I'm starting to get scared. Never did a clutch before don't even know exactly where to bleed it from. I know there are some how tos. But people say some are wrong? Anyone have a link to a good one I should go off of?
Old 04-19-2010, 11:01 AM
Saskdeltas's Avatar
i got my new clutch, flywheel done and it's impressive drove 380 miles one day the next i did 200 miles, went to work and then got home a week later and it was nice and ready for some fun
Old 04-19-2010, 11:57 AM
stenguyen1's Avatar
i see that you went with the same clutch as i did. i went and got the exedy flywheel as well. glad you got everything done. i love my clutch still. and that tranny job in the drive way is a bitch i did it all by hand and even had to lift up the tranny while on my back. its one job i'm not doing again lol
Old 04-19-2010, 12:43 PM
ml2242's Avatar
Originally Posted by elecblue06
a new flywheel is 85 bux
True, But Fred Jr. knows his ****, i think it was about 50 for the machining so it was still cheaper!
Originally Posted by Jn2
now I have to pump the clutch all the time or it starts engaging off the floor again...WTF...like I have to pump it, acts normal, after a few mins I have to pump it again or it engages off the floor..Gunna bleed it again tommorow...I ran out of dot 4 bottles
Sounds like some serious leakage.. I'd take it apart make sure everything's where its supposed to be and take your time bleeding it.
Old 04-19-2010, 01:33 PM
Jn2
Jn2's Avatar
Yeah it just started after the last time I bled it...weird...Ima make sure I closed the bleeder valve right
Old 04-19-2010, 05:12 PM
joshc.'s Avatar
Hey now we would of been done sooner if someone wouldn't have removed unneeded bolts.
Old 04-19-2010, 05:32 PM
Talic's Avatar
hey i just got this clutch also. but i noticed there was no throw bearing. did you use a stock one?
Old 04-19-2010, 05:34 PM
07cobaltguy's Avatar
I used the stock on but if i had to do it again i wouldnt. im starting to have issues.
Old 04-19-2010, 05:37 PM
  #36
Talic's Avatar
so you would buy an upgraded one? where do you get that?
Old 04-19-2010, 05:50 PM
  #37
Zdeuce4's Avatar
get a new slave from gmpartsdirect its cheap!!!!!!!!
when i got this clutch installed i got
new oem flywheel
flywheel bolts
new slave and the clutch and it feels and holds great
  #38
cobalt2007ls's Avatar
from what I know the f23 transmissions dont have an option for an aftermarket tob. I bought a stock on through gm.
Old 04-19-2010, 05:52 PM
  #39
slowswap's Avatar
There is no aftermarket throw out bearing, F23 or F35.
Replacing when doing a clutch is a must.
Old 04-19-2010, 05:55 PM
  #40
stenguyen1's Avatar
yea i know josh. that was all david's fault thinking he can take off the starter to take the tranny off.
Old 04-19-2010, 09:51 PM
  #41
Talic's Avatar
good to know, thanks alot guys
Old 04-19-2010, 09:55 PM
  #42
SlowBalt_06's Avatar
new oem flywheel
flywheel bolts
clutch isnt gonna be the problem...your syncros are gonna hate you
Old 04-19-2010, 10:16 PM
  #43
Zdeuce4's Avatar
wut are u talkin about
Old 04-19-2010, 11:26 PM
  #44
06_ion2's Avatar
Nah my cars fine with all the power it makes, just dont jam through the gears.
Old 04-20-2010, 01:36 AM
  #45
Jn2
Jn2's Avatar
Think I found my problem...so it seems the reason I have to pump my clutch is bc of bad bleeder/clutch pumper communication :p gunna have to re-bleed it again, just need to get another bottle of dot4
Old 04-22-2010, 02:44 PM
  #46
thesteed46's Avatar
Hey man, just curious, did you resurface your flywheel??
Old 04-22-2010, 04:01 PM
  #47
Zdeuce4's Avatar
yes he did. he said it a couple times.
Old 04-22-2010, 04:28 PM
  #48
thesteed46's Avatar
My bad. Where can you get it done at?
Old 04-23-2010, 01:27 AM
  #49
joshc.'s Avatar
A machinist can do it for you.
Synchros its all about welding second gear.
Old 04-23-2010, 09:26 AM
  #50
stenguyen1's Avatar
synchros are bitches. lol
Quick Reply: Excedy stgII clutch install
