Excedy stgII clutch install
#55
So went to the strip this weekend. Car did not want to go into 2nd at all under wot. Is this the problem with the synchros you're talking about? If so, what is the fix?
#57
stg1 exedy.
http://www.youtube.com/watch?v=mrIqdLb8Qpg
solutions:
still has air in the line. it like 100x i bleed it.
adjustable rod. zzp rod doesnt fit saturn ion. i have to weld a 3/8'' rop to extend it
use dot 5,1 work with higher temp.
#58
How about this? http://www.zzperformance.com/cobalt_...1196&catid=146
#59
he drives a cobalt it is gonna be this one: http://www.zzperformance.com/cobalt_...1096&catid=146
it is for a redline. i m not redline, i have no idea if it ll fit.
#60
Solution I have no idea, I've heard mixed stories about why it does this but no hard evidence.
#67
I mean it was still kind of hard to get in third but not nearly at bad. Also today I noticed while at stoplight at a slight uphill in first gear with the clutch all of the way to the floor I was rolling very slowly.
#75
bad. my daughter put a wrong key in my ignition switch. then i was not able to take out. key break inside ignition switch. but with a dremel i got it out. but my key doesnt turn anymore. the ignition is kind of lock onto the column.
