Excedy stgII clutch install
Old 04-23-2010, 11:42 PM
  #51
Jn2
Jn2's Avatar
yeah, had the flywheel machined...had a machine shop here locally do it for me, $40 was all it cost me...although they were pretty busy so it took a while for them o get to it
Old 04-23-2010, 11:48 PM
  #52
thesteed46's Avatar
So do you think a transmission shop could do it? I don't know of any machine shops around here.
Old 04-24-2010, 12:12 AM
  #53
Jn2
Jn2's Avatar
im sure if its a tranny shop they either do it in house, or have something set up with an outside company do do it for them...but they should know who can machine a flywheel..its part of working on trannys and clutches
Old 04-24-2010, 12:29 AM
  #54
thesteed46's Avatar
Alright, awesome, thanks for the info.
Old 06-27-2010, 07:25 PM
  #55
thesteed46's Avatar
So went to the strip this weekend. Car did not want to go into 2nd at all under wot. Is this the problem with the synchros you're talking about? If so, what is the fix?
Old 06-27-2010, 07:26 PM
  #56
Pedobear's Avatar
cool
Old 06-27-2010, 08:48 PM
  #57
huckernage's Avatar
i got the same issue
stg1 exedy.
http://www.youtube.com/watch?v=mrIqdLb8Qpg
solutions:
still has air in the line. it like 100x i bleed it.
adjustable rod. zzp rod doesnt fit saturn ion. i have to weld a 3/8'' rop to extend it
use dot 5,1 work with higher temp.
Old 06-28-2010, 02:47 PM
  #58
thesteed46's Avatar
How about this? http://www.zzperformance.com/cobalt_...1196&catid=146
Old 06-28-2010, 03:08 PM
  #59
huckernage's Avatar
he drives a cobalt it is gonna be this one: http://www.zzperformance.com/cobalt_...1096&catid=146
it is for a redline. i m not redline, i have no idea if it ll fit.
Old 06-28-2010, 03:57 PM
  #60
joshc.'s Avatar
For some reason the Cobalt Exedy clutches seem to do this my friends car with an Exedy stage 2 does the same thing. I have an Exedy in my Cavalier with no issues. If it was a synchro issue you would know because it would happen all the time not just under WOT, that gear would be useless without rev matching to get into it.
Solution I have no idea, I've heard mixed stories about why it does this but no hard evidence.
Old 06-28-2010, 04:07 PM
  #61
Zdeuce4's Avatar
mine goes into second much easier than it did with the stock clutch
Old 06-28-2010, 05:40 PM
  #62
thesteed46's Avatar
I'm thinking the zzp rod will work.
Old 06-28-2010, 07:16 PM
  #63
06_ion2's Avatar
Gotta push the clutch harder.
Old 06-28-2010, 10:28 PM
  #64
thesteed46's Avatar
It's to the floor man.
Old 06-29-2010, 05:25 AM
  #65
06_ion2's Avatar
odd, i just found out i had to press it a little bit harder because it wasnt all the way down.
Old 06-29-2010, 09:08 AM
  #66
joshc.'s Avatar
Even if engagement was off it would effect every gear not just second. Its worth a shot but I'm doubtful.
Old 06-29-2010, 03:21 PM
  #67
thesteed46's Avatar
I mean it was still kind of hard to get in third but not nearly at bad. Also today I noticed while at stoplight at a slight uphill in first gear with the clutch all of the way to the floor I was rolling very slowly.
Old 06-29-2010, 03:46 PM
  #68
elecblue06's Avatar
sounds like you clutch rod is bent so it's not fully disengaging
Old 06-29-2010, 03:53 PM
  #69
huckernage's Avatar
check it if it is bent. you can easily see it.
Old 06-29-2010, 04:00 PM
  #70
thesteed46's Avatar
Alright I'll check it right now.
Hmm it doesn't look bent.
Old 06-29-2010, 04:08 PM
  #71
huckernage's Avatar
advice.
if you are at the light and you cannot engage it. stop your car, engage it then restart again when you are ready to leave.
Old 06-29-2010, 04:10 PM
  #72
thesteed46's Avatar
Oh it engages fine, I don't have a problem with that.
Old 07-01-2010, 11:30 AM
  #73
huckernage's Avatar
tired to wait about zzp rod.
someone machined one for me
Old 07-01-2010, 07:26 PM
  #74
06_ion2's Avatar
awesome howd it work?
Old 07-01-2010, 08:01 PM
  #75
huckernage's Avatar
bad. my daughter put a wrong key in my ignition switch. then i was not able to take out. key break inside ignition switch. but with a dremel i got it out. but my key doesnt turn anymore. the ignition is kind of lock onto the column.
Quick Reply: Excedy stgII clutch install
