exhaust in front of axle is low ss/sc on 2.2
sorry if this is a repost i couldnt find anything about it in the search.
i just had the ss/sc catback installed on my LT sounds great btw, but i noticed yesterday that the part where it was welded back together hangs down pretty far, where the stock part was tucked under the car completly. my question is how should i remedy this
option 1 is to use exhaust straps and sinch it up
option 2 is to cut that peice out and have a new tube bent and welded in replacing it altogether
option 3 of course is to buy an after market when i have the cash
problem is it looks bad hanging down that low also with sportlines installed on the car its really low and might scrape any advice or pics of how you may have fixed this problem would be great.
the part that was welded
the car
the car
Kinda eliminates the whole reasoning for getting the cheaper SS exhaust instead of aftermarket......trying to save some money. Take it back to the shop that did it and tell them they welded it wrong.
i guess i will just leave it like that for now i already dumped a to much cash on the car this week plus i gotta have some money to make it to the austin meet this weekend maybe i can get someone there to take a look at it and see what went wrong
Mine is the same way, thats just how the SS/SC pipe fits. When I looked at mine its close to the floor pan already, there is no room to move the pipe up. I'm figuring nobody with an SS/SC notices because they have the side skirts.
i bought an aftermarket magnaflow and it hangs down just like the pic you showed... it doesn't realy rub on anything unless im just haulin ass over something....
ya i got a pic from another guy, his is the same. i think when i get some extra cash i will just have it cut and replaced. really wanted to know if anyone else had the same problem and how they fixed it
ya just got them this week and added the sportlines
well when i got home last night i had a stroke of genius, so i took a floor jack put it under the low spot on the exhaust pipe and lifted up till the back wheel came off the ground, i did that on 2 different spots. when i let the jack down the last time there was about 3 inches of clearence between the jack and the pipe that wasnt there before, i also took the jack and raised up the muffler till the exhaust tip was in the right spot then strapped it up with exhaust straps. then took a test drive. it looks a lot better now i will take some pics later.
DANRICKARD
10-01-2015 12:08 AM
