extra hose for injen intake?
there is a hose(3/4" plastic hose) that was originally connected to the stock filter box. Now that i'm putting on injen intake there is no place for the extra hose... if someone has run into this problem, please advise me of what i should do...
https://www.cobaltss.net/forums/2-2l-l61-performance-tech-45/secondary-air-injection-late-production-2006-l61s-38488/
ur cobalt is a 06 and might have this... which requires a certian intake...i will be more than happy to take ur injen off ur hands
i put the breather filter on yesterday and I have a check engine light on, will this go away or did i f up my car and need to take it in for service?
Connect the stock airbox back on for a bit and drive it and see if the CEL goes away. If it does then try the new intake again, maybe sure everything is tight on it. We had to use electrical tape to make a snug enough fit with the SAI and breather filter.
Heres a link to the How To I made on it, hopefully it will help: https://www.cobaltss.net/forums/how-guide-43/how-2-2l-sai-cai-easy-fix-85867/
thanks for everyones help, the CEL officially went away this morning when after I was driving around for about ten minutes. Thanks for all the tips, it helped a lot.
I'm old school
The CEL is probably more a result of the intake then the breather line. The extra air coming through the intake is not being metered by the MAF correctly, causing the CEL.
OrangeCoba
09-25-2015 06:06 PM
