F35 lsd?
F35 lsd?
has anyone tried this product out? its on ebay and its made by OBX. i ran across it and i was interested. i should have probably searched by im feeling lazy. here it is.
http://cgi.ebay.com/ebaymotors/OBX-H...Q5fAccessories
Rattlesnake Race Shop
OBX-R makes a lot of stuff for Honda's. They seem to be a pretty decent company from what I have heard.
I'd say that there is no use in getting it unless you have a way of putting it in. It's almost impossible to find someone with the tools to tear into our transmissions... and I don't even think that they sell the tools anymore, I'm pretty sure GM deemed it "Replace Only - NO repair".
Not to mention, it is a total PITA to tear apart... you'd be looking at another $500 in labor, at the cheapest. Just find a junk yard and buy a G85 F35. It'd probably cost you right about the same.
I believe it has to do with the clutch. From what i found out before it was the same bolt pattern, just the 6 bolt flywheel that made for the F23 wouldnt work with an LSJ clutch and the F35 transmission. I believe you would need a LSJ flywheel made in a 6 bolt pattern then you could put a F35 clutch and tranny in your car. I just looked into it briefly and thats what a couple of us found out.
problem is, if you want spec to make you one custom, they require a minimum of 10 orders at 350 each.
importkiller
09-30-2015 07:18 PM
jcalvin1126
09-11-2015 10:24 AM
