FF22's 2.2 build thread
Nothing too crazy here, a pile of bolt-ons (one internal) I've been accumulating for the last 2 years for my 2.2, and then getting a bunch of tuning from a local company called Revtronix, or I may drive down to washinton to get tuned by trifecta, but we'll see. Since having a mortgage, I've been cash-poor, so it's been a stuggle to make my ecotec faster..anyhow my list:
-2.4L intake manifold kit (Thanks Sentry!)
-Level Zero motorsports tri-flow camshafts
-4-2-1 Tsudo stainless header and downpipe
-custom 2.5" exhaust system
-Ported eco throttle body (62mm)
-Level Zero motorsports balanceshaft delete kit (haven't ordered this, but will be in next week after finding out it can be installed without removing engine)
-SS/SC cobalt injectors
Mods already installed - WAI, upper/lower motor mounts, lots of suspension/handling mods
So, I'll be posting updates here in the next few weeks, and I WILL be getting dyno's done after it's all installed..I wanted to get a baseline done but couldnt justify the expense when I already know how much power a stock ecotec engine makes.
So, any comments or suggestions?
Good luck! I don't know anything about sunfires, so you got tuning worked out for sure? Never heard of what ecm they use, or who supports them, etc. Trifecta may be the only way, but they're great for the money even if you have other means.
Did you get that manifold fixed? I know last I heard that vacuum nipple had broken off in transit to Canada. Hope all goes smoothly, you car will feel like a whole new beast.
That way you'll get into the higher rpm's quicker and that's where your camshafts will be making the most power. My 2cents
Where are you going to dyno at?
Racing Greed?
Pretty much the same 2.2L eco engine/ECU that's in the cobalts, bit less power due to crappier stock tune and different air sensor, and other minor differences like no drive by wire, etc.
