FI cost$$$$$
im a little over 6500 with just parts. i think i forgot some stuff.. heres most of it.
procharger kit
vulcan intake mani
ZZp header/dp
spec 3 clutch
wiseco pistons
eagle rods
ARP headstuds
79lb injectors + harness
throwout bearing
lsj head gasket
2.4 tb
Fmic + pipe
3in cat back
patriot stage 2 head
exhaust mani gasket
throwout bearing
bearing kit
and i got the rest of my nitrous stuff
procharger kit
vulcan intake mani
ZZp header/dp
spec 3 clutch
wiseco pistons
eagle rods
ARP headstuds
throwout bearing
lsj head gasket
2.4 tb
Fmic + pipe
3in cat back
exhaust mani gasket
throwout bearing
bearing kit
More than you want to know. Parts alone are about 3500 for my build, not to mention some of the custom work I had done.
A supercharged setup can be had for around 1000.
dam thats alot of money but im sure it was worth it. what i want to do is a staged clutch then the turbo kit from vulcan of hahn... im beting that will be around 4k at the most i wouldnt want to install my clutch. but the turbo kit i heard it is pretty simple so ill try to do it.......
procharger kit
vulcan intake mani
ZZp header/dp
spec 3 clutch
wiseco pistons
eagle rods
ARP headstuds
throwout bearing
lsj head gasket
2.4 tb
Fmic + pipe
3in cat back
exhaust mani gasket
throwout bearing
bearing kit
procharger kit
vulcan intake mani
ZZp header/dp
spec 3 clutch
wiseco pistons
eagle rods
ARP headstuds
throwout bearing
lsj head gasket
2.4 tb
Fmic + pipe
3in cat back
exhaust mani gasket
throwout bearing
bearing kit
